Hi Guys,
I have been searching all over the place trying to find information on this error I am getting but have been unsuccessful so in a last pitch effort I have come to you guys.
I currently have a Microtech LTX12S ecu wired into a 1JZ Cressida. I have run a complete new wiring loom for the new ECU install (which has been checked and triple checked by myself, a friend who works with these, and another friend ( piggy who has installed one himself).
The current problem is when I try to start the car I am getting a REF and RPM error showing up on the Microtech dash. The car seems to start by dies out.
Also while cranking I noticed that the RPM shows 250rpm but then drops to 0rpm and then backup again, I'm not sure if this is normal or not.
Another interesting note is when the car is turned off, 2-3 of the LED lights on the dash stay slightly illuminated which I found very strange.
I believe that the Crank Angle Sensor and Cam Sensor(rear one) are fine as I ran my setup on the stock 1JZ ecu just before wiring in the Microtech.
Any help or advice would be greatly appreciated.
Brendan
