Results 46 to 60 of 65
Thread: how to make two shafts rotate together... ???
  1. #46
    Default Re: how to make two shafts rotate together... ???
    Yeah, i think i can answer this one for Ed. From the pics ive seen he will be using 4 sets of 2 GTR plates on a custom manifold. Im pretty sure youve seen the GTR throttle plates around somewhere Ben.
    Happy Birthday too.
  2. #47
    Penrith BC
    ok - i think i solved it!!!
    30mm long cranks on 10mm dia shafts
    shaft separation of 77.5mm
    connecting linkage length of 55.1mm
    LINEAR 1:1 ratio of angular movement in the range from 14deg to 76deg +- 0.6deg !!!
    'wow' i hear you all say!!
    but, yes, it is only a 62deg range of motion, not a full 90deg, but i think i can over come this by changing the ratios of the crank lengths at the throttle bodies (turning 62deg of main shaft rotation into 90deg of throttle body shaft rotation). i can probably tweak a bit more out of the 62deg, but it wont be much...
    either way, its solved! - no crazy discs or bellcranks or gears. no slop. nice and simple
    ../delete/ban
    tech moderator
  3. #48
    Good work.
  4. #49
    Awesome...now do it
  5. #50
    Penrith BC
    I AM hehehe...
    I had to get this sorted so that i could finish a CAD diag of the manifold adapter plate. Im trying to include everything into the one plate to keep it simple, and that includes mounting holes for the bearings on which these shafts will run. thats why i needed to figure out how far apart the shafts should be.
    freakin complex cad diagram too i should add. bloody 1uz - nothing is symetrical
    ../delete/ban
    tech moderator
  6. #51
    Are you doing away with the entire vvti intake manifold?
  7. #52
    Any chance of a sneak peek? I would love to see what that manifold would look like.
  8. #53
    Junior Member Automotive Encyclopaedia Nim's Avatar
    My idea would provide you with a direct link between the two throttles, and provide you with a linier throttle.
  9. #54
    Penrith BC
    Quote Originally Posted by Nim
    and how would you do that?? pls explain? remember - shafts have to counter rotate...
    anyway, pic of manifold as requested:
    ../delete/ban
    tech moderator
  10. #55
    Looking liek a good setup, are you going to angle those runners slightly so that you get a more direct airflow, or is it going to stay pretty much vertical?
  11. #56
    Penrith BC
    the ports on the vvti heads are vertical, and thus that manifold provides direct flow already. looking through an open throttle body, i look straight down the port in the head, and look onto over 80% of the back of the valve face
    ../delete/ban
    tech moderator
  12. #57
    Ah, i havnt seen a VVTi 1UZ head, and was struggling to remember the angle which the non-VVTi heads are at. Sounds good though, would be more than ideal
  13. #58
    Quote Originally Posted by ed_jza80
    I did explain it. In my little diagram thingo.
  14. #59
    Penrith BC
    nim, did you read the comment after your post?
    Quote Originally Posted by shinybluesteel
    thats even more complex than two gears, and gears = slop.
    EDIT: it will also make both shafts rotate in the same direction
    ../delete/ban
    tech moderator
  15. #60
    Penrith BC
    ok, for those that were interested...
    from one side to the other:
    34mm crank on throttle butterfly
    58.24mm linkage to main shaft crank
    45mm main shaft crank
    34mm main shaft inter-link crank
    63.14mm inter-link linkage
    back to 34mm main shaft interlink crank
    58.24mm linkage to crank on throttle butterfly
    65.5mm from centreline of throttle axis to centreline of main shaft axis
    89mm centre to centre between the main shafts
    not sure tis will EVER help anyone, but now its here just in case
    ed
    ../delete/ban
    tech moderator
  1. I keep getting email notifications!! MAKE IT STOP!
    By bathurst-91 in forum Toymods Car Club Membership and Feedback
    Last Post: 16-12-2005, 09:09 PM
