Results 16 to 30 of 52
Thread: putting a GT oil/amp guage into a LT (2T) TA22
    Classic Not Plastic Domestic Engineer ace's Avatar
    Default Re: putting a GT oil/amp guage into a LT (2T) TA22
    Ohhh that would've helped me! I took my dash out, got the guage bolted in, got the pressure sender in and then couldn't work out the wiring so i gave up
    Hopefully i can use this info/my guage in another TA22 one day tho
    Ace
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Hoppers Crossing
    folks, FWIW you can buy a VDO gauge sender from a T18 for this setup
    the part number is 231.084
    it costs $9 bucks so i wouldn't even bother with one from a wrecker
    the sender suits 76 onwards celica, t18 and corona.
    EDIT 24/10/2009 - apologies 231.084 is not correct.
    Going to try a Tridon TPS-005 sender from a Toyota Celica RA40R, 4, 2.0L, Eng code: 18R-C, 1/11/1977 - 1/10/1981
    Last edited by Grega; 24-10-2009 at 07:19 AM. Reason: apologies 231.084 is not correct.
    Hoppers Crossing
    more information for all those who care ;
    whats interesting is the gauge works on heat believe it or not. the sender grounds out and provides resistance which heats up a metal strip inside the gauge which causes the needle to move. the more resistance created the more the gauge will move)
    learn something new every day
    Thanks for that Grega, Theres also other brands that do the oil pressue senders but thanks for the part number.
    My TA22
    Quote Originally Posted by Grega
    The temp gauges for both oil & water work that way, but how would that work on a pressure gauge? When you first start the engine and it's cold you get your pressure reading, and the reading stays the same when the engine is hot - which implies it is not dependant upon temperature.
    Furthermore, when the revs vary on an engine the oil pressure goes up and down (with the revs) and I can't see how there would be temperature variances causing the pressure gauge to move under these circumstances.
    I would assume the pressure sender would have a small hole where oil gets in and pushes a diaphram which in turns moves some form of potentiometer which varies the resistance to earth, which is then interpreted by the gauge to provide the indicative pressure.
    seeyuz
    river
    Hoppers Crossing
    river - i've yet to pickup the gauge so will ask for a more detailed explanation when i do and report back mate. thats a fair assumption though.
    Im still just a......... Backyard Mechanic NoRecall's Avatar
    Tasmania
    Help has allready been provided, Soz.
    Last edited by NoRecall; 28-11-2006 at 12:39 PM. Reason: What i said was already said!
    From Tassie?
    Junior Member Backyard Mechanic scottsta22's Avatar
    In need of assistance ASAP, I am installing the GT oil/amp gauge and need someone to tell me what my wires correspond to, I have one solid yellow, one yellow with white stripe, one yellow with black stripe, This is from a '75 LT.
    Cheers & thanks in advance
    Scott
    Carterton
    Scott,
    The Yellow/Black wire is the signal from the oil pressure sender (which you will have tapped into the engine block after removing the oil pressure switch).
    The Yellow/White wire is the signal from the alternator which would have powered the CHG idiot light in the original guage. Its no use to you any more.
    The Yellow wire is the power feed to the oil pressure guage.
    Mike
    71 TA22
    My Car
    FRustrated INdividuaL !! Grease Monkey Rosey's Avatar
    Just wondering Mick where does the negative come from to get the gauge working, I was thinking it came from the regulator ( which I think is the Yellow/White wire ) correct me if I am wrong.
    Cheers Rosey [email protected] Rosey's GT TA22 Celica - 72' Model
    Quote Originally Posted by TheToyman75
    For me its the 1st generation GT's I'd Kill for a 72 GT but since most people don't even believe they exist
    Junior Member Domestic Engineer TA22 GT's Avatar
    The negative wire on the 4 pin plug is from the same source as the other gauges. Pretty much they all join to a common earth. This is the white/black wire.
    Simon
    Quote Originally Posted by TA22 GT
    Simon
    Okay but Scott does not have the white/black wire, I think in place of this wire is the Yellow/white wire which I think still goes to regulator. To act as an earth.
    Carterton
    Quote Originally Posted by Rosey
    I have never seen how the wires connect into the idiot light guage but would suggest Scott is better to connect the Yellow/White wire (from the Oil/Amp guage earth connection) into the dash harness earth strap (White/Black). There are several spare earth connections close by on the dash harness to do this.
    This will at least ensure that the oil pressure guage function is not influenced by the alternator/voltage regulator performance.
    Mike
    71 TA22
    My Car
    Sounds good Mike, I'll email him now as he is putting all back together as we speak.
    Thanks Mike, Rosey & Simon.
    Got it all worked out now. I'm taking a break from it now and will finish installing it in the morning.
    Scott
