Results 31 to 45 of 48
Thread: T series rear end diff centre change guide (warning, pics!)
    Raastler Grease Monkey
    Default Re: T series rear end diff centre change guide (warning, pics!)
    If I cant get a Drum Cover off by just Twisting and pulling off by fingers, i just give it a phew taps with a hammer or mallet around the sides to loosen it up, it usually works everytime.
    Quote Originally Posted by Matt-AE86
    A "phew" taps eh
    Probably works on newer diffs, but old crusty ones, no such luck
    Looks like this thread has been deemed unworthy of the FAQ
    Western Aus
    A "phew" taps eh
    his is old and crusty too, just probably not as old, and not as crusty
    Eldar.O.
    Junior Member Backyard Mechanic bathurst-91's Avatar
    bananaman>
    thats is farken scary you have the same jack stands, jack and rear-kmac springs as me.. Nice guide too
    -Andrew
    A race continues forever...
    Ah, because you can often get the problem where the axle is actually stuck. Sounds like yours came off quite easily. But personally ive had one where one axle came out fine, but the other took forever and a day to get out. Tried with a large sledge hammer and no luck, ended up using a slide hammer and pop, out it came.
    If you think about it, its a much more concentrated force, on a smaller area. So not as much distribution.
    Tools are EVERYTHING. I remember the first T series rear end I was doing (needed centre taken out also) so I needed to pull the axles out. 1 came out fine, the other.. literally 3hrs of everything I tried it wouldnt come out. And i mean EVERYTHING>
    After hitting it with a sledge for 25min I got some rope. Tied it around the axle, the other around the other side of the rear end, then tied one side to my van and the other to my hachi. And guess what happened? I actually started to pull my ae86 with the ropes and the t series being elevated mid-air by the tension. I dragged the car about half a metre and gave up.
    Eventually went out and got the proper tools
    -Andrew
    Quote Originally Posted by bathurst-91
    bananaman>
    lol something tells me they're a bigW/supercheap kit or something? I do have the same jack, but i'm afraid the pictures your referring to were contributed by Karl
    This isn't worthy of the FAQ section then? If it is, feel free to move it in, its been lost in the woodwork
  8. #38
    Tasmania
    Another way to make an axle puller is find an old axle,knock the studs out,Slide a piece of pipe over the axle then weld some handles to the axle and viola you have your very own genuine Toyota axle puller.As for getting brake drums off just give the front face of the drum a few hard taps around the face which should dislodge all the dust and crap and it should basically slide straight off.
    Cheers Brett.
  9. #39
    got 71? Grease Monkey cooter's Avatar
    wa
    just a note axles can be really really stuck in if theyve not ever been out. we tried everything on my mates mk11 escort axles (sorry not toyota) n they still wouldnt. we ended up getting the dingo with a chain wrapped around the end of the axle and attached to the bucket then another chain wrapped around the other end of the diff housing and to a big tree to yank it out. STILL WOULDNT COME OUT!
    so back went the dingo and out came the bobcat. same thing as with the dingo but much more force obviously. took 5 full power pulls to get it out. be careful but. the axle came out so fast i didnt even see it n flew into the bucket. very easily coulda got me.
    God i love being a redneck
    my axle puller ive got now is roughly 2 inch dia steel pipe at 2.5m long with many many bits of scrap steel welded to the slider for weight. with handles of course. welded a plate to one end of the pipe then flattened and hooked the other end to hold the axle. works a treat.
    craig
    (ps i sudjest having a front gaurd on the bobcat if using one.)
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
  10. #40
    tasmania
    i think that everyone that had trouble getting the drum off the axle just forgot to take the handbrake off!
    ..seriously, i've never had trouble getting one off, they just slide off easy with a hand tap and a jerk.
    beer me!
  11. #41
    Hope this digram will help with this thread
  12. #42
    Quote Originally Posted by joecoolmk2
    You're probably right, i more than likely didn't consciously make an effort to check it was off, probably just rocked up when the car was already parked
    Exploded diagrams are always good, +rep
  13. #43
    Can someone fix up the photos so I can see something?
    Please?
    Toyota Car Club (Qld)
  14. #44
    Yeah i'll have a look through my pics tomorrow to dig up the ones of mine that were in here, but karl will need to find his, i don't think i saved them.
  15. #45
    NT
    so no pics on this? i have to replace a 2 way mechanical - will it be much different?
    By The Witzl in forum FAQ
    Last Post: 19-10-2007, 09:43 PM
