shinybluesteel: dont you have a welder. If you do, then simply get a piece of steel rod about 8mm OD and whack a weight over the end. Then just weld the end of the rod to the knob on a pair of multigrips, and block off the other end (or put a nice handle on it) and voila one homemade slide hammer.
). The blue oval thing is a steel weight with a hole drilled through the center so it slides over the steel bar. And the end of the steel bar is welded to the adjustment screw on the locking pliers/multigrips.
