Results 16 to 18 of 18
Thread: t series diffs
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Default Re: t series diffs
    Rex confirm this, He did it today also.
    As stated above the complete T18 tailshaft is the correct length and fits in the back of the K40/50
    The T18 handbrake cables, and brake line fit perfectly also.
    The T18 diff also appears to add some track to the rear over the stock KE70 Borgie (U-series?) by eye it looks like approx 15mm either side.
    If yer lucky enough to find a T18 Anti-RollBar diff then the ARB fits perfectly also
    Rex
    If not then getting handy with a MIG and angle grinder does the trick perfectly. I know many people who havnt been able to tell the difference between my T18 diff with cut off S-series mounts to a stock ARB bracket diff. Then again, the welder who did that one was top notch.
    Quote Originally Posted by Rex_Kelway
    Non Sequituer. Stepho's site indicates U series rear end for other-market production but that doesn't mean there's anything U series about the KE70 Borg Warner diff. Quick google search is inconclusive as to whether the KE70 Aus Borg Warner sedan and TE72 Aus T series rear end is different track/width or not.
    Also as a side note, different engines and transmissions in various E70 chassis were paired with a variety of rear ends on a global basis. ie. AE71 panel van (Aus) with leaf S type differential (like Aus-delivered AE86), CE70 (Europe) sedan with S series rear end behind 1C diesel and W50 trans, and TE71 GT and Levin specification (Japan) with 2T-GEU and T series rear end.
    By The Witzl in forum FAQ
  2. Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Last Post: 19-01-2015, 05:18 PM
  3. Guide: How to build a K series motor
    Last Post: 19-10-2007, 08:43 PM
  4. IS200 Altezza Type 2 Torson LSD into MA61 IRS F series?
    Last Post: 27-12-2005, 08:53 AM
