Results 1 to 6 of 6
Thread: 4AGE throttle cable arm
    Junior Member Grease Monkey ehendrikd's Avatar
    Default 4AGE throttle cable arm
    Hi all
    Just wondering if anyone knows of any cars (doesn't have to be toyota) that have an eliptical throttle cable arm on the throttle body. The reason is, in my spontah the travel distance of the accelerator pedal matches the closed-to-open of the butterfly nicely. But whenever I drive it it feels like the first 2cm are from open to closed, and the rest of the pedal travel does nothing. This has become a little bit of an issue on dirt racing, as its hard not having a more proportional control, feels kinda like "off" or "full wheelspin" lol.
    The current "arm" (if thats the right terminology) has a constant diameter, so we are thinking that if we replace it with an elipitcal shaped one (starting larger then moving to smaller) the more fine grain cortrol over the throttle could be acheievd.
    anyone have any ideas? I know we could possibly change the pedal movement geometry to acheve the same thing, but replacing the arm could be a more elegant and easier solution.
    Evan
    Default Re: 4AGE throttle cable arm
    I just cut and shut mine to get the same sort of effect. You can get away with a constant curve if it isn't centred on the shaft.
    You could always go for something like this and fiddle with ratios to your hearts content...
    I am needing to do something similar to mine, Bens idea sound like the simplest way to go.
    My KE25 thread
    Think about it carefully, I did mine backwards the first time
    thanks for the replys guys.
    that customisable linkage looks quite interesting, but could probably knock one up at home
  1. Info Needed: 4age FWD Throttle Cable
    By GTZLevin in forum Tech and Conversions
    Last Post: 28-06-2006, 03:40 PM
  2. Replies: 24
    Last Post: 18-04-2006, 01:42 PM
  3. ra23/ra28 linkage to cable for 18rgu
    By krohla-10 in forum Tech and Conversions
    Last Post: 29-03-2006, 12:45 PM
