when rod is pushed down, i don't think it will have much of an issue... the force pushign bearing down will go thru original line? but the reaction force from the bearign will be offcentre (more on one side)... so will that cause the rod to push sideways a little?
when rod is being pulled down, the actual clamping axis is off-centre... will that induce a bending moment into the bolt?
then again.... assuming you are using the original crank, then the big end and little end centrelines will still be aligned no? if the big end little ends are alinged still, but centreline of rod is off.. there may be some bending induced... but if you shave the big end, the little end also needs shaving? or??
as for the friction surfaces, they can be relieved to reduce the actual contact area...
intuition says it is a little funny, but i spose it depends how over-engineered the rod is, in terms of being able to take non-symmetrical loading (but you could model the change fairly easily)
edit: i have no idea.. just guessing![]()
