Results 16 to 20 of 20
Thread: Toyota Bearing Grading Sheets.......
    Default Re: Toyota Bearing Grading Sheets.......
    jesus even a 600cc daihatsu has 47mm ID!lmao
    'plenty have the same OD but not even close to having 32mm of meat!
    yeah that doesnt sound right does it...hold on ill check my numbers rather than hwat i scribbled on htis sheet...
    :S
    hmm, i have all the specs but not sure which you would need,
    main journal diameter?
    if not, im not sure...
    what numbers would u like as my info doesnt tell me anything about the thrust washer other than it should be 1.990 mm
    cheers micky
    nothing in any make or model that is close! few are 1.99mm but the rest is out!
    yeah, its a PITA
    ill try NDC if not i may be bending over for toyota genuine
  1. 1G-GTE Bearing size grading sheet??
    By Karma Supra in forum Tech and Conversions
    Last Post: 08-06-2006, 09:19 AM
  2. Injector flow figures website.
    Last Post: 27-03-2006, 11:00 AM
  3. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 12:58 PM
