Results 1 to 4 of 4
Thread: St141 Corona rear brake conversion! Please Help
    grease monkey Grease Monkey
    Default St141 Corona rear brake conversion! Please Help
    Hey guys i have been searching for a while about the corona rear brake conversion for a TA22 celica and i just cant find anything. Anyways problem is that i have everything to do the conversion but am unsure what bearings i should run? and other then changing the bearings and the bearing retainer plate, is there anything else that might cause troubles? Any help would be appreciated....cheers
    Scott
    Default Re: St141 Corona rear brake conversion! Please Help
    Do you mean the rear disc brake conversion? I'll try and find they article on it. Im sure it was here a little while ago.
    Bit of info here
    http://toymods.net/forums/showthread...ghlight=avante
    The old One Backyard Mechanic
    Ta22boy
    I wrote a technical article some years ago on this conversion for the old forum. I have tried to retrieve it recently, and again today but cannot seem to get to the old forum Some months ago I posted a thread requesting that all of the old tech articles be moved to the new forum. Maybe you should follow this up with the Club.
    Craig
    what? Automotive Encyclopaedia EVOSTi's Avatar
    you need to buy new bearings cause you will damage them when you remove them to switch the retainer plates over. and BE CAREFULL with the retainer plates that you dont damage the ring on them. i did this and it was a absolute BITCH to get it back together cause the ring fits in real snug and if its slightly egged, youre in for a world of pain. trust me! my axle seal is leaking on one side but it is the side i damaged the ring on and as such i aint taking it back out to fix the leak.
    By The Witzl in forum FAQ
  2. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 12:31 AM
  3. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
