It is not always necessary to have all the idle air passing thru a single
opening. For example, the E92 4AGE uses the idle air bypass screw to
supply a base amount of idle air and then makes adjustments to the
total by means of a small PWM controlled IACV.
If supplying enough air thru the EGR channel causes a problem, a
similar strategy could be employed on this engine providing there is a
programmable ECU available to control the IACV.
Cheers... jondee86
 Each bank gets two plugs fired by the inner ring
