Results 16 to 23 of 23
Thread: Guide: DIY MA61 Rear Spring Replacement
    Default Re: Guide: DIY MA61 Rear Spring Replacement
    Also use more jackstands. Using just the one under the diff is nasty dude.
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Agreed on the stands... there are some nice rear subframe mount points which are perfect for jackstands - two will be better than one, especially since that one point is a pivot point.
    One thing about not unbolting the axle flanges is you can use the pulling force of pushing the suspension arms down to get the axles moving out of the diff... but there are easier, less destructive ways of doing this
    Spring clamps are good if used correctly. They only become a danger if the person using them doesn't respect them (or if they are put on springs too small!!)
    Otherwise, nice work I hope the rear tyre wear doesn't wear too bigger hole in your pockets.
    Thanks for the advice, I'll be sure to remember that next time. I don't want anyone (including myself) getting crushed by their supra
    Quote Originally Posted by Hydra
    ... he he he we'll see Hopefully not
    definantly more chassis stands, and definantly spring compressors... 4 hours you should have been able to do both front and rear and then have beers
    also when you pull the shafts off the half shafts on the diff, grab a white paint texta and index them so you make sure to put them back in the same rotational position .
    *Edit* but of course had you used spring compressors undoing the shaft wouldnt have been nessecary.
    but definantly be careful with spring compressors but if your sensible they pretty safe. like all things in the shed.
    Quote Originally Posted by TooF
    Oops I just put them back, it wouldn't be doing any damage would it?
    should be sweet but it is just good practice to do index any rotating parts and put them back the way they came out.
    Noted, thanks for the advice guys
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Its the same with live rear ends aswell, if you replace an axel always use one from the same side. I haven't seen one break because it was in the wrong side (because I always use the same side ),but I have heard of it.
    Edit : if thats what you were talking about of coarse, and if not then its still handy for everyone to know
    By The Witzl in forum FAQ
  2. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 12:31 AM
  3. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  4. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  5. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
