Page 3 of 9 FirstFirst 12345 ... LastLast
Results 31 to 45 of 125
Thread: OBD Serial Data
    Default Re: ODB Serial Data
    All the info that I have, you also have
    Pretty sure it is a 17, the same as the first word...www.asciitable.com shows that as being "DC1 Device Control 1"...(it looks bracketed by 17
    Why would 19 make more sense?
    17 is XON
    19 is XOFF
    I'm thinking that the last word is prbly data...but not sure yet.
    I've written my program (micro controller based atm) to get the data, works a treat!
    I can see values change on the screen...i.e. the tps as i move the throttle!
    Next I will work out what each word is relating to (rpm, tps etc) and then I will work out the resolution of each. Almost there for me I suspect!
    Junior Member Backyard Mechanic ndgcpr's Avatar
    I will have a shot at getting a 1G-GTE system up and running.
    mine won't be too technical as i don't have the time, i may just do a log and try and find stuff
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    Junior Member Backyard Mechanic 82MKII's Avatar
    Bloody great effort Wilbo!!
    You've gotten far further with this than any of us before.
    Keep up the good work - I'll be keen to see the final data definition.
    Regards
    Peter
    The Elektor magazine has an OBD-II analyzer project.
    http://www.elektor-electronics.co.uk...ProductID=2582
    seeyuzz
    river
    Quote Originally Posted by river
    seeyuzz
    river
    BZZZZ, ODB-I needed here old man!
    Ta tho.
    Ahhh.... ODB-I, I think that's in the Nov/Dec 2002 Elektor magazines.
    seeyuzz
    river
  9. #39
    http://www.elektor-electronics.co.uk...h=11&art=50765
    Still OBD-II there...
    "Vehicle Diagnostics Adapter (1)
    Interface between an OBD-2 vehicle diagnostic connector and a serial PC port"
    I am however looking for the following Toyota Publication if someone knows where to get hold of a copy!!! (list of available here)
    ITEM NUMBER:
    00401-TH874
    MODEL OR YEAR DATE RELEASED:
    3/13/2002
    MARKETING:
    Toyota
    DIVISION PRODUCT DESCRIPTION CURRICULUM:
    874 Engine Control Systems II (Diagnosis)
    CATEGORY:
    Engine
    DESCRIPTION:
    This course is designed to provide technicians with the skills necessary to
    practice advanced diagnostic processes. Use of the diagnostic tester and
    vehicle functions to acquire, analyze and interpret various types of data will be
    covered. The course will focus on data gathered from the engine control
    system to identify and service system malfunctions.
    wil - ask John Lapworth if he can pass on the request to some of his old mates at Toyota - he might know someone up the food chain who knows someone who...
    cheers,
    Charles.
  11. #41
    this seems to be stating that there is nothing interesting in the signal????
    http://uktoyotaestimasite.tripod.com/obdcodes.htm
    or is this something else?
  12. #42
    it's not very interesting in that you can't interact with it, nor get logged events like OBDII - and most tech's only use it via the check-engine light and think of it as morse-code. But there is useful data there somewhere
  13. #43
    Quote Originally Posted by ndgcpr
    Missing something
    That is just the OBD codes.
    Toyota also has serial data avaliable....check the following doc
    47 OBDII#2 - Serial Data.pdf file size 289KB
    Some info is also in 46 and 48 I recall.
    Hi Wilbo,
    This is bloody cool!! Glad to see there's people on here playing with micros and all the jazz that goes with it What micro are you using?
    How are you coming along with working out the meaning of each byte?
    The bit stream you posted earlier - that was received at 100baud, is that right?
    (Now how to find more free time...grrr)
    Mos.
  15. #45
    Got my serial data coming out now and into the laptop. Just got to figure out how to do the timing now. Doesn't look too bad. I'll post some pics shortly.
    BTW I just put the data straight into one of the parallel port status lines and just keep reading the register (379 bit 7 normally used by the printer to tell the PC its busy). It will run upto about 100Khz.
  1. Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Last Post: 19-01-2015, 05:18 PM
  2. More 4-to-5 stud hub conversion data
    Last Post: 19-01-2006, 12:40 AM
