Page 9 of 9 FirstFirst ... 789
Results 121 to 125 of 125
Thread: OBD Serial Data
  1. #121
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default Re: OBD Serial Data
    JZX83 didn't work with the local tester. Whacked it on a VCV10 Camry V6. This is the order they come out in and the units of measurement.
    Injector - ms
    Ignition - 'CA
    ISC Step # - ##
    Engine Spd - RPM
    Airflow - v
    Coolant - 'C ***
    Throttle - %
    Vehicle Spd - km/h ***
    Target A/F L - v
    Target A/F R - v
    A/F FB Left - ON/OFF
    Knock FB - ON/OFF
    A/F FB Right - ON/OFF
    STA Signal - ON/OFF
    IDL Signal - ON/OFF
    A/C Signal - ON/OFF
    OxL Signal - RICH/LEAN
    OcR Signal - RICH/LEAN
    *** - These units can be changed in the setup menu of the tester, along with MAP/MAF units if the car has one (kpa, mmHg, g/s, lb/s etc)
  2. #122
    BK Grease Monkey bk_'s Avatar
    Quote Originally Posted by bk
    What I'd like to check for interest sakes if whether a PowerFC outputs toyota OBD1 information.
    Hmm... I should have realised.... PowerFC does not simulate toyota OBD data output. Confirmed it today.
  3. #123
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Hi, looking to build one, but dont want to start from scatch with the pic board.
    did any one use a pre built board like the below listed or can suggest an other starting point.
    PIC40 Prototype Kit for 40 Pin Microcontroller 16F877 | eBay
  4. #124
    Nov 2007
    N.S.W
    Hi, Just wondering if there is an off the shelf device which will do this OBD ? or is it still build your own ?
  5. #125
    I was tempted to commercialise it but could see close-to-zero market demand for it, let alone be able to make a "product" out of it.
    Not only that, in terms of useful features I could create was zero, due to the update cycle (once every 1.3 seconds) of the protocol.
    Trying to find one of these used would be quite a challenge (then again, techtom were the Toyota chipped-ECU masters back in the day): MKIV.COM
  1. Toyota diffs. All data being collated onto one table. Specs/input needed (RWD)
    Last Post: 19-01-2015, 05:18 PM
  2. More 4-to-5 stud hub conversion data
    Last Post: 19-01-2006, 12:40 AM
