you may find that there is an air lock in the system, causing it to over heat. is there a bleed screw on those engines?
you may need to run the car with the radiator cap off and the front jacked up, hopefully this will get the air to circulate and come to the highest point. that being out the radiator.
give that a go and see what happens.....
also it progressivly gets hotter and hotter the most its gotten to is about 130 C but thats way too hot i might get a thermal fan while im at it i think
