May have one in the garage as I have a few w5x bellhousings. How do I identify it?
				 WTB: W to m series bellhousing
				Hi I'm after a bellhousing to suit a 7mgte with a w57 need bellhousing and clutch fork thanks in advance
 Re: WTB: W to m series bellhousing
				Hey mate I've found a pic of one the starters on the right hand side looking from the motor face and the clutch fork is just below it if that helps or just send a pic to me on 0400951233 cheers for your input been hunting for awhile now with no luck hope to hear from you
				http://www.supraforums.com/forum#/topics/656416 here's a pic
				You can have mine fir $40 plus post...no clutch fork unfortunately but go hydraulic slave cyl instead?
				cant see pic but if JustenGT8 has one then grab his? I probably also don't have a clutch fork but would have to check the forks I have
				Had a look and the bell housing that maybe a 7m one has the starter and clutch fork on the side you are describing but safer to get JustenGT8's one if he is sure it is 7m. The clutch forks I have aren't 7m as I have a few 125mm from centre of pivot point to centre of slave cylinder rod indent. Apparently you need 113mm as below
notched = M, K (km36 G52), K A & T (only from 22spline T50) (shortest type) approx 113mm pivot to clutch slave
straight = T (3tgte), G, C (ce71), (middle type) approx 118mm pivot to slave
bent = R, S, C (cr30 G52), (longest type) approx 125mm pivot to slave
SamQ sells 22 spline T50 forks and clips whch looks to be what you want but best to ask for measurements on the fork
http://www.sq-engineering.com/replac...utch-fork.html
http://www.sq-engineering.com/replac...clips-x-2.html
				Hey mate sounds good I'll grab that bellhousing and slave I know where I can get a fork from anyway so where do we go from here sorry new to this site
				Justengt8 here's my number 0400951233
				No slave cyl either sorry although I have a few lying around that would probably suit....they are cheap as chips new though so better off with a new one I reckon...plus can buy the right ratio then to suit your master cyl and clutch throw?
Anyways, pm me and we can sort out payment, freight etc
				How do I pm you on here I can't find it message me on facebook if you'd like Erik Neil Miller
