Results 1 to 2 of 2
Thread: Sealant to use between metal/plastic gasket and inlet manifold to head
    Nov 2007
    Default Sealant to use between metal/plastic gasket and inlet manifold to head
    Hi Guys.
    I have a bit of a dilemma. I have a manifold that is going onto a head, the manifold has some low spots on it, nothing too drastic.
    The type of gasket is a metal one with black lining, I believe some sort of urethane or plastic.
    I have enquired about RTV, which I got told by Permatex and Loctite can have issues adhering to the gasket if I used it to fill the low spots,
    and got told to use an aviation type non hardening sealant instead, the ones that are found on those little small bottles.
    This area see's boost and coolant aswell - I was afraid that the boost could blow out the soft non hardening aviation sealant, I have before used this for water pumps and had a leak which is why I wasn't really too keen on it.
    So I'm wondering have any of you guys often used something in this exact scenario, where you are still using a gasket of this description
    but need to put some sealant here and there, what do you use?
    Dec 2012
    Default Re: Sealant to use between metal/plastic gasket and inlet manifold to head
    I have reused metal gasket/polymer coatings heaps of times with a thin smear of ultra black or grey.
    You could also consider having the mating face decked at minimal cost for reassurance.
  1. 1GGTE inlet manifold gasket
    By tomo1ggte in forum Tech and Conversions
    Last Post: 06-04-2010, 02:58 PM
  2. Head gasket sealant
    By willwal98 in forum Tech and Conversions
    Last Post: 15-12-2009, 07:56 AM
  3. Metal Head gasket 4AG(T)E 20v
    By blacktop in forum Tech and Conversions
    Last Post: 13-07-2007, 07:53 PM
  4. O-Ringing an inlet manifold gasket.
    Last Post: 24-01-2007, 12:07 PM
  5. Where in au to buy metal head gasket?
    By omy in forum Tech and Conversions
    Last Post: 22-06-2006, 06:36 PM
