Results 1 to 15 of 24
Thread: Metal Head gasket 4AG(T)E 20v
    Aug 2006
    Default Metal Head gasket 4AG(T)E 20v
    Are the 16V head gaskets interchangable with the 20V motors?
    I ask cos i can only find Metal H/G listings for the 16V motor.
    What would be a reasonable price to pay?
    $150 to much for a Cometic?
    Brendan
    Default Re: Metal Head gasket 4AG(T)E 20v
    i've used a 16v HG on a 20v rebuild. though there they are some differences in the coolant holes between the 2 gaskets.
    isnt the 20v toyota one simular in build to the gze one? the stock 16v HG handles boost well.
    Forum Sponsor Conversion King
    how thick do you want the gasket coz last time i checked TRD ones were around $90
    S.A
    I would be interrested to know what a cometic gasket is worth and the sizes / thickness the are available in.
    I know HKS gaskets are $400 odd ........... so $150 for a cometic sounds 8-9 cartons of piss cheaper.
    Aug 2006
    This is where i will be getting mine from
    http://www.rocketindustries.com.au/s...?brand=Cometic
    Part number: CMC4170-040
    .040 Thick
    81mm Bore
    I asked my local Toyota about a TRD H/G and i was told "phew!!! looking at big dollers there mate, i would just go something from Autobarn if they have it"
    So i did what any smart person would and went to Autobarns supplier
    Junior Member Domestic Engineer psychofox's Avatar
    16V and 20V head gaskets are not the same.
    http://www.toymods.net/forums/showthread.php?t=8330
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    New Zealand
    use the gasket to suit the head.
    TRD p/n is 11115-ae001 for the 20v 0.8mm gasket. rrp should be no more than $130ish aud
    stock 16v/4agze gasket is the same part.
    HKS = rip off!!!
    please, no more PMs!
    I had my TRD 20v 0.8mm gasket in vic delivered for $105 all up
    Aug 2006
    Delivered from where?
    did you have to order it interstate?
    I'm thinking 0.8mm would be a lot better for my application (the whole turbo thing on stock compression)
    http://www.greenline.jp/
    you know it raises your compression right?
    Aug 2006
    Shit! is it possible to use 2? or is this just stupid?
    What's the standard thickness of a 20V h/g compared to the 0.8mm TRD version?
    New Zealand
    stock gasket is 1.2mm
    you can use 2 TRD ones, or as they are sheets, split then ans use differeing numbers of sheets
    1.15 from what I was told but yes well said on the gaskets, for the price you can afford to do it
    New Zealand
    1.2 when torqued to spec according to the EPC and manual
    Quote Originally Posted by Mr Revhead
    is that before or after torqueing it down?
    (edit: too slow )
  1. 3sgte head gasket worries
    By milosamun in forum Tech and Conversions
    Last Post: 27-03-2007, 03:13 PM
  2. Quick Q - 2JZ / 1JZ Valve Cover Gasket
    By AndyTTR in forum Tech and Conversions
    Last Post: 30-09-2006, 11:10 AM
  3. Head gasket question
    By chubbylover53 in forum Tech and Conversions
    Last Post: 22-04-2006, 05:08 AM
