Results 1 to 2 of 2
Thread: Wiring in SP1 for late model A341E Transmission?
    Jan 2017
    Default Wiring in SP1 for late model A341E Transmission?
    Hi guys,
    New member! I just replaced the blown A341E transmission in my 1993 UCF10 LS400 with a later model A341E from a 1995 UCF20.
    Later model transmissions don't have SP1 sensor ports so now I have no speedo or cruise control. Other than this, the transmission is working great!
    Is there a way I can tap into the SP2 signal to feed the speedometer?
    Alternatively, there is a round indentation in the transmission casting where the sensor could go. Could I drill and tap that to insert the sensor? Perhaps the inner gears don't exist though in the later trans? Both transmissions were listed as 30-41LE.
    Martin
    May 2010
    Moscow
    Default Re: Wiring in SP1 for late model A341E Transmission?
    I make speedo/tacho signal converters which can fix your problem
    Or you can use parts from your old transmission to fit the 2nd sensor
  1. Replies: 3
    Last Post: 16-06-2016, 01:19 PM
  2. w57,early w58, late model w58
    By nalchlan in forum Tech and Conversions
    Last Post: 29-09-2014, 03:11 PM
  3. How many Transmission Output Splines on A341E Transmission
    By MickJ in forum Tech and Conversions
    Last Post: 08-08-2014, 12:55 AM
  4. Who has built an A341E auto transmission?
    By mick08 in forum Tech and Conversions
    Last Post: 02-12-2013, 09:05 PM
  5. Replies: 6
    Last Post: 24-05-2007, 11:02 PM
