Drain the converter, else you've only changed half the oil. IDK if yours has a drain, but look or just drain & fill again, 1/4 old stuff left in it seems to be acceptable.
Find a wiring diagram, & put 12v to the trans solenoids that are on for R or just do all of them a dozen times. Do they all sound similar, nothing much different or sticky/slow/delay response to current?
Clean the valvebody?
WHAT WAS in the sump & filter!!!!!!
How many times do you try it when it happens, and run through all of them?
"pretty annoying when you have to push it out of carparks." Or push it in, drive it out.![]()
