Results 1 to 8 of 8
Thread: 4age sohc - to match race rules - advice please
    Jul 2012
    Gauteng
    Default 4age sohc - to match race rules - advice please
    We are looking for a good (1600 sohc 8V) race motor for a specific oval class. It is a short track 2nd gear circuit. It has to be 1600 8v (class rules). You may modify / mix components. I was wondering about the 4age with a 4ac head. I appreciate the head will have to be worked and we will fit EMS and FI. I would think the 4age engine with oil squirters as we would try and get the CR as high as possible maybe 14 or 16:1 if possible. We will run race fuel. That little 4AGE motor just loves to rev!
    We were considering the 2tg or even a 3TGTE head (they do not specify the number of cams - yet!!) but 2tg's and 3TGTE's are like hens teeth here - but plenty 4AGE's and all the trick bits.
    Maybe you think we might be better off with an Opel or VW 1600 8V (also lots of "stuff" available) modified motor?
    The advice from you guys who have the experience would be appreciated. Thanks.
    Jul 2007
    Default Re: 4age sohc - to match race rules - advice please
    there are probably other 8v sohc engines with more aftermarket support than a 4AC head, which is what might swing things
    also a 2tg wont work as it is a twincam, even though it runs an 8v head. you would need a 2T head if you went that path
    Jul 2012
    Gauteng
    also a 2tg wont work as it is a twincam, even though it runs an 8v head. you would need a 2T head if you went that path[/QUOTE]
    Thanks for the reply.
    As the rules are at the moment they specify "1660 (max)cc and only 8 valves". ie They do not exclude "twin cam". So we might be able to race a hard to source 2TG initially, but think they could amend the rules to exclude "twin cam 8V's". With regard to the 4AC it is a non crossflow / U head. Is this going to be of concern / a limiting factor?. We can have the head ported, flowed and polished professionally, but is it worth all the trouble?
    Is there any other option anyone can think of on 4AGE or another suggestion?
    It is a glassfibre body, space frame, Wilwood brakes, rwd w58 box and locked M75 diff.
    Jul 2007
    ah ok i thought by your thread title that the engine needed to be sohc.
    non crossflow heads are definitely not ideal, and 2TGs can be made to punch out a decent amount of power. I would go for the 2TG if it were me
    Sep 2007
    Georgia
    victoria
    I assume the 1660cc capacity applies to as run, rather than as manufactured condition.
    In this case have you considered putting together something based in the toyota R series family.
    A toyota 9R (1500cc 8v 82kw stnd) would be a perfect base, but good luck finding one!
    A more easily found combo would be a 12R block with an 18RG head.
    The biggest issues I can forsee would be clearance for the inlet valve(89mm bore v 80.5) and sorting out the cam drive(shouldn't be too hard).
    If you wanted to spend money a custom 66mm short stroke crank and 89mm bore piston would give you the revs to make pretty impressive numbers.
    Keep us posted on what you do!
    Jul 2012
    Gauteng
    Thanks for the info Celicapain. Yes you can put any combination together even if not from the same manufacturer as long as it is 8v and 1660 max. Will definitely have a look at your suggestion. I think it all depends on availability of the components.
    Victoria, Mt Macedon
    If you want a 4AC head I'd consider just using a whole 4AC motor. I've heard the head design is pretty average, but you could surely improve it somewhat.
    The only other thing that springs to mind for me is the Datsun L16. Rally boys love the L series motors and can get some big numbers out of them, so there should be good support.
  1. 4age/ze - Race Harmonic Balancers from $320
    By Bazda in forum MRP LTD - Manon Racing Products
    Last Post: 13-02-2014, 08:03 AM
  2. Why DOHC and not SOHC ??
    By Enchanter in forum Tech and Conversions
    Last Post: 24-02-2006, 12:35 PM
