Page 1 of 4 123 ... LastLast
Results 1 to 15 of 49
Thread: 4age/ze - Race Harmonic Balancers from $320
    Jul 2008
    Auckland
    Default 4age/ze - Race Harmonic Balancers from $320
    Hey Guys,
    We are putting together an order for BHJ Harmonic Balancers.
    These balancers are Very well designed, alot of Atlantic spec 4ages in USA are running these with great success.
    http://www.bhjdynami...e=index&cPath=9
    Custom made Harmonic Balancers from BHJ suit all 4age types.
    Single & Double row will be available. Also with Dry sump pulleys for our dry sump kits
    Single Row Pulleys $400NZD (Approx $320AUD)
    Double Row $480NZD (approx $385AUD)
    4agze 175mm pulley TBA
    * Listings for all 4age series - 16v, 20v Silvertop, 20v Blacktop
    * Accepts Dry Sump Mandrel with Chrysler Bolt Pattern Mount (Jones Racing mandrel DH-8101-WC-C, or equivalent - not included)
    * 3-Bolt 2.80" Bolt Circle Pattern with 2.248" Male Register in Face
    * Single 5-Rib Serpentine Pulley
    * Optional Bolt Patterns Available
    * Internal Balance
    * 4.9" / 124.46mm O.D.
    * 1.88" / 47.75mm Overall Length
    * 2.3 lbs. Gross Weight
    * Billet Aluminum Hub/Steel Inertia Ring Construction
    * SFI 18.1 Certified
    Now 9AGTE 410kw atw
    Jul 2007
    Default Re: More 4age goodness - Harmonic Balancers & Crank Scrapers
    ho do you go about setting the timing on this pulley? will it have cutouts like the factory one or do we have to do something different? trigger wheel etc?
    hurry up and get pricing up for that crank girdle too
    Jul 2008
    Auckland
    The pulley will have TDC marking on it.
    Yes the Girdle I still haven't finished the 3d model. Will get onto it lol.
    Now 9AGTE 410kw atw
    Chiba
    I need a new harmonic balancer (some previous tard used a 2-jaw bearing puller and broke mine, right where the timing mark is....), so count me interested in one suitable for an OEM replacement on a 4AGE silvertop.
    Also gotta get back on a set of those coilovers too.....
    Oct 2009
    I was under the impression a harmonic balancer was not required aka run a lightweight aluminum crank pulley?
    Jul 2008
    Auckland
    Quote Originally Posted by TERRA Operative View Post
    No worries! just let me know when and we can suss it out.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Quote Originally Posted by dnegative View Post
    Only if you want to kill your engine bearings faster.
    Now 9AGTE 410kw atw
    Oct 2009
    Never heard of anyone having issues, people have been running them for quite some time?
    I was under the impression the stock pulley was just that, a pulley with a rubber bonded/isolated grooved section for the belt.
    Jul 2008
    Auckland
    Its an additional safety product as all after market balancers are.
    They reduce the harmonics in the engine. On race engines they are very effective if you pull down engines after each season you will notice how much it saves the bearings.
    Its easy to google search to find the pros of them.
    Now 9AGTE 410kw atw
    Chiba
    What do the bearings look like without a harmonic balancer? Do the wear normally, but faster or do they get signs of brinelling or similar?
    Myself, I'd rather play it safe and use the rubber.
    Jul 2009
    Is it possible to get these done with a HTD-8M tooth pullies instead for gilmer drive setups?
    I'm 50% through making a tooth belt drive (machining down stock 4A harmonic balancers) for my 4AGZE due to there being no tooth belt kits for the supercharger, only the water pump and alternator, which is lame and they are badly priced
    Jul 2008
    Auckland
    Quote Originally Posted by knightrous View Post
    Its possible yes, but a 1 off isnt going to be a real cheap price.. I would have to find out.
    Now 9AGTE 410kw atw
    Junior Member Conversion King
    May 2010
    Any intention on making these for a bolt on upgrade for stock GZE engines? i.e. Just as Nevo did.
    If so I'd be very interested in pricing.
    Jul 2008
    Auckland
    Quote Originally Posted by maj View Post
    Id need to send these guys a stock 4agze pulley to copy.
    Now 9AGTE 410kw atw
    Jul 2008
    Auckland
    Now 9AGTE 410kw atw
  1. AE82 and AE92 Harmonic Balancers : Are they the same?
    By Grega in forum Tech and Conversions
    Last Post: 18-03-2008, 09:18 AM
  2. crank scrapers- anything in it
    Last Post: 04-09-2007, 04:09 PM
