Results 16 to 19 of 19
Thread: ra28 aluminium radiator & elect fan questions
    Default Re: ra28 aluminium radiator & elect fan questions
    I have a single 12" Davies Craig fan on my alloy rad in the RA23..... which has a BEAMS 3S-GE.
    No shroud, pull through (Davies Craig fans can flip the blades to be pull or push).
    Steady as a rock temps, even on 35º days in stop start traffic.
    It's triggered by the ECU to come on at 90º, and off at 85º iirc....... the tuner set it up so i cant remember. Either way it's solid.
    Victoria, Mt Macedon
    Quote Originally Posted by Omegaman View Post
    Its hard to know if push is better than pull. when the car is speeding up, more outside air is being forced in naturally.
    Would this free flowing air overtake the speed & push the fans make, at some stage??? Hence now becoming a hindrance to natural air flow.???
    It's true that thermofans really only help when stationary or at low speed. As soon as you get some decent speed up (30km/h??) the natural airflow will mean a fan is not doing much to help.
    And I'm not sure if I've misunderstood what you've written, but using a push fan you always mount it on the front of the radiator, and a pull on the back. So fan flow direction always matches natural flow direction.
    Sydney N.S.W
    Quote Originally Posted by Hen View Post
    What I meant was, that the push (front mount) would hinder the flowing air into the core at higher speed. As opposed to the pull (rear mount) which I believe should have a limited effect on the flow of natural air.
    Good to hear a 12 " is adequate for cooling. I feel confident my new setup should be fine also.
    I will have the fans triggered from the ECU also. Can't wait to the weekend to fit this thing.
    Sydney N.S.W
    Finally fitted. see build thread.
