Results 16 to 18 of 18
Thread: 2JZ-GTE MX83 Cressida Build
    Feb 2016
    Default Re: 2JZ-GTE MX83 Cressida Build
    Thought i might add some of the random Photos i have -
    The Remainders of the Halfcut after i took erry thing i wanted from it. The Dump picked it up and gave me $10. hahaha
    Beating the crap out of the firewall to get some turbo Clearance
    YOU WILL NEED THESE! Freaking Coil Pack Clips.... From the heat in the motor they get Destroyed and no longer hold. Just replace them.
    Now.
    Previously up i did write i would put up how to fix your Shifter from feeling sloppier than a being the 4th guy in turn for a 3 way.
    Pull out the shifter and pull off the black backing rubber.
    There is 4 Screw you need to remove and it literally falls apart.
    The Bolts you can see here - are the ones where the shaft pivots. - Remove that bolt.
    You can see where the rubbers should be. There is nothing there.
    This is with the new bushes installed. I linked a photo from ebay on what you need on page one.
    There was NO Bushes left inside this originally.
    Give it a damn sand and a respray to avoid any future Rust issues.
    It was covered in so much damn grease...
    And Done!
    Maybe to help Someone in the future -
    1991 MX83 S2 Wiring Plugs behind Dash
    White plug
    yellow with brown spots___________ Dash Speedo Sensor
    brown _________________________ Earth for Speedo
    yellow_________________________ Temp Sensor
    black__________________________ Tacho
    yellow/blue _____________________ Oil Pressure Switch
    red/green [2] __________________ Reverse light on Dash
    green__________________________ Park light on Dash
    red ___________________________ Neutral light on Dash
    blue___________________________ Drive light on Dash
    light green______________________ Gear 2 light on Dash
    pink __________________________ Gear L light on Dash
    Square Grey Plug
    small black/white _______________ AC clutch
    blue/red_______________________ FP diags Not needed
    black/red _____________________ +B diags Not needed
    red/black _____________________ 12v supply for speed sensor etc
    big black______________________ Neutral Start Wire
    big black/white _______________ Neutral Start Wire Signal From Starter Relay
    light green ____________________ Loop wire back into other plug Not needed
    green with spots _______________ tccs diode Not needed
    green/white ___________________ Stop light switch (used for ecu controlled Cruise control) Not needed
    big black/yellow________________ Power from Ignition
    small black/yellow _____________ Solenoid 2 in transmission to cruise control ecu Not needed
    green________________________ From airflow for circuit opening relay Not needed
    black _______________________ From temp sensor on water inlet to start injector (Helps start car if warm)
    Rectangular grey plug
    pink__________ _______________ TE1 diags Not needed
    brown/black __________________ Earth
    pink/green__________ _________ TE2 diags Not needed
    grey________________________ VF1 diags Not needed
    purple/white__________________ Other end of that Loop
    grey/green___________________ ABS Rubbish Not needed
    pink/blue ____________________ ABS Rubbish Not needed
    purple ______________________ ABS Rubbish Not needed
    Feb 2016
    So its been a while since ive posted anything, May as well update for future reference.
    A fair bit has happened since the last post. Family. Daughter being born. You know, Standard things...
    First off i got sick of the Twins. They were going to be an absolute nightmare when it comes to the exhaust side of things as they want to come out straight where the steering rack is...
    They had to go.
    10/10 would NOT Recommend. One of the shittiest jobs ive done in a while
    Of course the Exhaust Gasket is cracked. New one time
    At least removing the twins made way for exciting times!
    GT35 Time
    Grabbed a Walhbro 255 of Fleabay, Slapped it in so i can actually keep up with Boost levels...
    Old trash 26 Year old Toyota Pump
    Of course when going to a single turbo from Twins you need to modify the drain... Toyota originally has a 2 - 1 Pipe
    Feb 2016
    Rip that off - Throw a Single AN10 Drain on
    Been working on the intercooler piping - Its been welded up by a mate as i cannot weld to save my butt
    Not a whole lot has happened with Tailshaft... Hopefully in a few weeks will be on the road ready to boost!
    Did a few more things on the weekend with the Intercooler piping and Fittings, Starting to look like a real car
    The Front Bumper needed a fair bit of massaging - I want it too look like a stock car
    Piping all done
    Finished Product
    Just for funnies the missus went out one night so i was on dad duties while my car needed attending too.. Improvised.
