Results 1 to 4 of 4
Thread: 4AGE running problem - Got many stumped ?????? (AE82) Electrical
    Default 4AGE running problem - Got many stumped ?????? (AE82) Electrical
    Ok, so, I have this 4age AE82 which I am trying to get running right. Sounds easy enough, but it's got many of us stumped.... Doing my head in......
    I will do my best to explain this well, so please read carefully.......
    So, the car is a clean 100% unmolested factory AE82 4AGE bigport. I bought the car for my brothers first car 6 years ago. He drove it for a few years until it started fucking up on him to the point where he couldn't run it.... He was young, and NOT mechanically minded at all. He bought another car and it has sat for almost 3 years in our mothers backyard in Melbourne.......
    I finally got a chance to drive to melbourne a month ago to pick it up......
    Now, what my brother had described to me when it died, sounded like a vacuum/map/tps type issue.... Sure enough, alot of the vacuum lines were broken/cracked/perished. I replaced these.....
    Second, the engine would crank very slowly, and would drain the battery or jumper pack pretty much straight away.... Even when jumper cables from another car, the cables were getting very hot. Anyway, after a few tests, I found I had continuity between the + and - battery terminals..... I traced this back to a short in the DOME circuit. I've pulled the fuse (drivers kick panel) from that circuit and it fixed that.
    Car cranks freely and runs........
    BUT.... (now, here is where this gets complicated)
    It runs, but very strangely....
    * It only runs properly on 2cyls.... Cyl #1 and #3.
    * if I have all 4 ignition leads on the motor, it runs worse, compared to if I have 3 leads on. IE; runs better on 3 leads (or even just 2 leads infact)....... Now, it doesn't matter if I disconnect cyl # 2 or #4 leads, both have the same effect. For a motor running on 2-3 cyls, it seems quite good, but connect a 4th lead (lead # 2 or #4), and it still runs, but worse.......
    * If I pull the lead off cyl # 1 or 3, it will stall and die (so these 2 appear normal)..
    * So, you would prob now be thinking I have problems with cyls # 2 and 4. NOT THE CASE..... Why? If I earth either of the 2 or 4 leads out on the body etc, it has the exact same effect as if I was to be connecting it to the spark plugs, therefore making the actual motor cyls irrelevant etc....... So it's an electrical issue.... Also, the results of a compression test was 180,177, 177, 178, so compression is fine.....
    * I have changed spark plugs, then swapped between cyls etc, and no change...
    * I have tried 3 differant sets of ign leads
    * I have swapped the coil and ignitor from another working AE82 and made no differance...... I have 12-14v at the coil..........
    * Alternator is working and charging, 14v when running
    * I have tried another ECU
    * I have cleaned tested the dizzy cap with a multimeter, and appears to be fine. Inside dizzy "looks " fine and clean.
    * now, when checking the spark from the coil, the spark in orange and weak, not blue at all
    * when checking when spark from the dizzy, they are all orange, but leads #1 and #3 are clearly much stronger. Leads # 2 and #4 are weak as piss......
    I hope this is making sense, I was dreading on how to explain all this.....
    Here is a video to try to give you an idea of what I am trying to say..... Watch and listen carefully......
    The last thing I haven't changed is the dizzy itself. I have tracked one down and pick it up tomorrow. I don't quite know how/why a dizzy would cause weak spark from the coil, or even why it would not work properly on 2 cyls only, but I am running out of ideas
    So, if brief,
    Why would earthing out #2 and #4 leads on body drastically effect running motor? (and why would #1 and #3 leads/cyls be fine)
    Why do I have such a weak and orange spark?
    Default Re: 4AGE running problem - Got many stumped ?????? (AE82) Electrical
    If there has been a short, are you confident the ecu is ok?
    I have tried a second ECU (already mentioned above)
    I just picked up another dizzy....
    All fixed now....
  1. AE82 4AGE thermostat problem
    By GTi Gaz in forum Tech and Conversions
    Last Post: 12-07-2014, 07:04 AM
  2. ae82 electrical problem.
    By sleepyu in forum Tech and Conversions
    Last Post: 21-09-2009, 11:58 PM
  3. Running Lean - stumped as to why
    By CrUZida in forum Tech and Conversions
    Last Post: 28-04-2009, 01:08 PM
  4. Replies: 4
    Last Post: 13-03-2007, 10:44 AM
  5. AE82 4age electrical problem help
    By rxjohn in forum Tech and Conversions
    Last Post: 28-07-2006, 07:50 AM
