Results 1 to 4 of 4
Thread: AE82 4AGE thermostat problem
    wa
    Default AE82 4AGE thermostat problem
    Hi All.
    I recently purchased the car and I am starting to go through and do all maintenance work that appears to have been neglected for a while and one of the things I did last weekend was replace the coolant and thermostat as the car refused to come up to running temperature on the drive to work.
    It still does not come up to temperature! Curiously though if I do 90km/h instead of 100km/h on the freeway it is fine...
    Its getting cold in the mornings and I would like the heater to work!!!
    Any help would be much appreciated.
    Gaz.
    Dec 2008
    Wellington, NZ
    Default Re: AE82 4AGE thermostat problem
    If the engine is slooow to come up to temperature, fails to reach temperature, or drops in temperature while driving, the thermostst is not doing its job. It would seem that yours is stuck partially open. It is not unknown for thermostats to be bad straight out of the box, but before buying a new one, test the one you have. Simple enough... just get a pot of water near boiling (90-100 deg) on the stove, tie a thin piece of wire to the thermostat and suspend it in the water.
    The thing should go from fully closed to wide open in 20 or 30 seconds. If it doesn't close fully it is bad. If it doesn't move at all... it is very bad
    Cheers... jondee86
    Jul 2007
    it could also not be sealing around the housing properly and the coolant is just bypassing it?
    toyota genuine thermos seem to be the only way to go with 4As. i have always had issues with non-genuine thermostats in the past.
    wa
    Thanks guys, I will grab a genuine item and let you know how that goes.
    Cheers.
  1. 4AGE 20V RWD Thermostat Relocation Kit
    By Bazooka in forum Tech and Conversions
    Last Post: 21-10-2007, 07:43 AM
  2. AE82 4age electrical problem help
    By rxjohn in forum Tech and Conversions
    Last Post: 28-07-2006, 07:50 AM
