Results 46 to 58 of 58
Thread: 18RG rebuild OR 1G-GTE
  1. #46
    Default Re: 18RG rebuild OR 1G-GTE
    Dear god, they're woefully inadequate! Even my RA60's brakes aren't much to write home about and they're miles better. Sure they stop...but they only do it once.
  2. #47
    User Conversion King
    NWA
    how about building a 18RG like this
    hello
  3. #48
    Either your friend's Windsor-powered Celica is incredibly slow or he never touches the brake pedal. The stock Celica brakes are, without a doubt, woeful. I managed to get them smoking hot with a stock 18R-G on a few occasions, and that says it all really.
    anyone who was on the toyota car club cruise to sommerset dam some time back (only 5 cars ) saw the smoke coming off mine just BEFORE we went down the other side of Mt Glorious... but on the other hand i've also found my brakes to be pretty damn good, has pulled the car up nicely, did a defensive driving course, and i managed to impress the instructor pulling up in the wet quicker then some of the later model ABS cars...
    and yes, my brakes are stock, engine 1G... but i wouldn't recommend doing it... i failed to adhere to the "do it right, do it once" principal
    '77 RA28LT #2 ← 2.2L 18RG...
  4. #49
    Thanks guys!
    All good so far. Just waiting on a reply from a friend in regards to a 1G-GTE. Anyone know of someone in perth that is familiar with the wiring? Also is there any prefernance / difference between the w5x gearboxs?
    Thanks
    PS: I will be submiting the forms to the council soon! It should be full steam ahead shorlty!
  5. #50
    NWA
    CrUziDa would probly do your wiring. either that or get the diagrams and suss it out yourself
    hello
  6. #51
    Are then any real differences between 1G-GTE and the 1G-GZE in terms of installing and upgrades required. I saw a 1G-GZE for sale this morning. I don't see many posts / threads with this type of engine mentioned. Are there any problems with this enginge? What engine would you choose?!
    Chears guys
    Anson
  7. #52
    Hi Anson
    obvious difference is the GTE is turbo and the GZE is supercharged. I have made some enquires into this engine myself and have been told they are tuff motor but hard as hell to get
    your hands on. If I was to choose between the two I go for the GZE to avoid the hassle of
    turbos.
    my experience with turbos is limited, only had one car that was factory turbo. I'd prefer
    to have the extra grunt in in the low end rather than the top end where turbo's work.
    Turbos rely on the exaust and need to spin up to provide to boost (lag time) where superchargers dont because there driven by a belt. They will suck some HP off your motor but will put more back afterwards. about a 30% gain give or take.
  8. #53
    Forum Member 1st year Apprentice pwrn's Avatar
    but superchargers last the longest and doesnt need much piping and bits its almost like a bolt on performance compared to turbos i suppose.
  9. #54
    there good points i missed. plus less extra heat build up under the bonnet.
  10. #55
    The innefficiency of superchargers require more fuel to be provided to produce the same performance gains. This also means there is more bottom end stress for the same gains. So, supercharged engines require larger injectors, larger fuel pumps, as such draw more power from your alternator, so your alternator works harder, your bearings and rings also work harder etc etc. A supercharger will also produce heat from the gas compression process, which will result in the requirement of similar amounts of plumbing as a turbo to get any real performance from it. The supercharger requries a gimble belt drive, so you need an inch or more wide belt hanging off the front, extending the length of the motor, and the super charger needs to sit somewhere inline with the alternator, power steering pump and air con pump, thus limiting the space available. Turbos when setup correctly can be made to provide good boost at low rpm, and therefore the lag will only be a PITA on initial takeoff, and be negligible on gear change. To further reduce lag, you can opt for a ball bearing turbo.
    So, as stated by others, superchargers do have advantages, but this is mostly over poorly setup turbocharger systems. Brett_celicacoupe didnt seem to have any performance problems in his 1GGTE powered RA40, and his motor is stock other than an intercooler and a home made dual stage boost controller.
    I think either motor would be fantastic and youll love it, but they both have their own unique advantages.
  11. #56
    i fully agree i have seen endless arguements about superchargers vs turbo, they are like holden vs ford
  12. #57
    Quote Originally Posted by pwrn
    Take that back... they are not the same argument!!!!!!!!!!!!!!!!!!!!!!!!!
    SC vs Turbo is about which is BETTER
    Holden vs Fraud is about which is LESS BAD
    See the difference??
  13. #58
    Junior Member Alien's Avatar
    good one anson you should/should have buy/bought my 1G
    oh well good luck with it mate, is a very nice car... perfect for a project/hobby
  1. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 10:09 AM
  2. 18RG into SA63
    By sa63-18RG in forum Tech and Conversions
    Last Post: 05-02-2006, 07:09 PM
  3. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 11:20 PM
  4. 18RG rebuild Q's
    By tricky in forum Tech and Conversions
    Last Post: 30-12-2005, 12:58 AM
