for starters , i think you wil need a front bulge sump. so you may need to track down one or get yours modified.
i fitted a 18rg to an RA60 celica once. it was going to be a track car but that plan fell through. i had it driveable and everything .
regarding mounts, (assuming SA63 has same mounts as RA60) the 18rg mounts sit much further foward then the mounts on the crossmember. you you may need a piece of steel, 10mm x 100mm with 4 holes in it to match it all up.
if i ever got my conversion closer to a race car then i would have put 2 triangular pieces of webbing along it for strength.
hmm...hard to explain really. probly best for you slot the engine in without a clutch because you may have it in and out a few times before you finish.
