Hi George, the problem with the door cards is that they are hot pressed. The cover is literally laid on the cardboard/wood backing, then a heated press is lowered into place, within a couple of seconds the vinyl is imprinted with the design and fused to the backing board. To achieve a result similar to factory finish will be nearly impossible.
For some cars with a metal skin at the top of the door trim, we can replace the backing wood with 3mm MDF, then simply have someone stitch up a nice hot rod style skin you can mount to the board.
cheers Chuck.
