What happens to them, as in is it always the inner or outer race & in spot all over the bearing surface that breaks down & how do you press them in ?? & after fitting New bearings do the wheels spin freely or drag ?? or have excessive wheel bearing clearance ?? & as its a engine swap are the drive shafts the same ones that suit the hubs ..
No offence but I suspect you are doing something wrong or something is not compatible since the conversion as you know they should be good for an absolute minimum of 100-200,000 km or even the life of the car in some cases ..
