Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: 20v cooling issues
    Jul 2007
    Default Re: 20v cooling issues
    Quote Originally Posted by DX20VT View Post
    The blacktop and silvertop do interchange, but they are different.
    The thermostat sizes are different, and the covers are too,
    so the thermostat over must match the housing.
    Also no TRD thermostat listed for the silvertop, only the blacktop.
    Fucking excellent. Thank you good sir +rep
    Edit; the silvertop uses the same thermostat as a 16v, so you can look up a TRD thermostat for an AE82/92/AW11 for them. The blacktop thermostat is supposedly same as a 3SGE unit
    I did an oil chage last night using 10/60 and bugger all difference...gauge sender is kaput me thinks?
    Jul 2007
    Maybe you have some extremely low resistance bearings?
    Sounds like the gauge is crap. What brand is it?
    There is a Tridon high-flow available that is compatible with the silvertop. Although I really don't see the point in either. The blacktop thermostat is huge and I doubt that even the normal silvertop one would cause any worthwhile restriction. In my experience all 4age engines run fairly cool.
    The blacktop manual is available on line in english, I suggest seeing what it says about oil pressure:
    http://locost7.info/mirror/4age_blacktop.php
    Kaput sensor from a brand new gauge Justen? Seems unlikely, although you did buy a sh1te brand
    A cluster full of Stewart Warner or bust on this thing dude, it's worth it.
    Feb 2007
    Timaru
    i did briefly attempt to run the stock pressure sender wiring off it as well for the dash light...dash light worked but not the gauge as the voltage signal was obviously effected....i can't see this having munted the pressure sender though?
    If you hook up a light to a sender that is meant to run a gauge you can and usually do damage the sensor,
    as they are not meant to handle even the small amount of current that a bulb has.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Hmm might have toasted it then.....warranty job me thinks
    Yup sender dead it was
    New sender installed and oil pressure is cranking gotta love supercheap teenagers fir warranty claims
  1. Radiator Workings - Cooling issues 1uz->Ra23
    Last Post: 08-11-2011, 06:03 AM
  2. W5x clutch pedal issues/Slave issues?
    Last Post: 11-05-2010, 06:27 PM
  3. aw11 cooling issues
    By KARNAGE in forum Tech and Conversions
    Last Post: 30-03-2008, 03:01 PM
  4. Cooling/Heat Issues
    By Dimmy in forum Tech and Conversions
    Last Post: 21-03-2008, 04:27 PM
  5. Cooling issues...
    By MWP in forum Tech and Conversions
    Last Post: 24-07-2006, 07:53 PM
