Well fellas I got some good news...I spoke to Peter from Waggot cams and basically he can do the 1G cams for us. All you have to do is give him a call on the number 0266283795 that CruZida provided and tell him some info where your cams are dialled in before you remove them.. Now I don't know too much about Overhead Cams but the end result is for about $700 dollars all our 1G engines can benefits from punchier bottom end (read less lag) and a stronger midrange. Peter also mentioned by using a Dual patterned grind you can achieve this without sacrificing top end. This would be great for people with stock turbos and even for JCMF and my self with upgraded Blitz BAG CT12's... since the CT12 aren't too efficient anyways up top. Also when you put the cams back in you have to check the Shim clearance and you will probably need to change the shims to archive appropriate clearance with the new cams. He told me this is not too much of a problem as many shims are universal and can be found with the clearances we require.
So if anyone is interested I am trying to organise a group buy so maybe we can negotiate that price.
