Results 1 to 9 of 9
Thread: 4age silvertop computer issues
    May 2014
    vic
    Default 4age silvertop computer issues
    Hi guys,
    Put a silvertop into a suzuki sierra been driving around having a ball but its been charging at about 15 volts sometimes up to 15.8 at times. Drove it into the shed last night all good. Now it wont start, pulled a plug and theres no spark.
    Checked 12v into computer, all good, but nothing out of IGF or IGT. Is it possible ive cooked the computer with voltage or is there something else i should be checking?
    May 2014
    vic
    Default Re: 4age silvertop computer issues
    Also sorry mods i somehow put this in the wrong section. please move it if you can.
    Jul 2009
    Possibly a dead coil / igniter. Test if your getting 12v at the coil terminals.
    Jul 2007
    thread moved
    May 2014
    vic
    Have swapped a new coil and igniter and another o2 sensor i flashed the codes and it comes up with 21 which is o2 sensor. I swapped in another and no change. Surely this shouldn't stop it starting though?
    Nov 2011
    no o2 on a silvertop only makes them sluggish off the mark sometimes
    check for spark on each plug
    check for injector pulse on each injector
    check for fuel pressure
    check timing
    check inside ecu for leaking capcitors very very common
    Beer anyone?? Domestic Engineer Just1n_mc's Avatar
    Depending on where you are in Vic I've got a spare ECU you can try.
    1970 2M MS55 Crown - Weekend Cruiser.
    1970 2R RT40 Corona - Cruising Grandpa Style
    1986 20V 4AGE AE82 Corolla - The Brown Racecar.
    1988 4AGE AW11 MR2 - Sold but not forgotten
    1992 1MZFE SW20 MR2 - Sold Supercharged V6 Monster.
    Mar 2012
    I have seen heaps of silver top ecus with leaking capacitors inside them. Take the lid off and have a look. The caps leak dark stuff that can eat at the circuit board. Try metho and a toothbrush to clean it and get new caps from Jaycar.
    May 2014
    vic
    Cool ill open it up tonight and have a look. Im in kinglake. its an auto computer, i have another but its a manual one and i feel a bit cbf about changing the plugs over haha
  1. Idling issues with a 20V silvertop on an AE101
    By dencio1976 in forum Tech and Conversions
    Last Post: 11-02-2009, 01:32 PM
  2. Replies: 13
    Last Post: 07-08-2008, 09:35 AM
