Results 1 to 5 of 5
Thread: Combining a 1JZ-GE (N/A) and a early version W58
    West Australia
    Default Combining a 1JZ-GE (N/A) and a early version W58
    Hi All,
    Ive got the following to complete soon :
    1JZ-GE + Auto from a JZX90 Grande (will bin the auto)
    W58 from a MA61
    2JZ-GE W58 Bellhousing
    After a few hours of googling this morning ive found a little bit of info from Toymods in 2007-2010... however ill ask the brain trust again as MUCH of the info provided was semi-sketchy, even from Wilbo!
    Questions:
    1JZGE - Is the flywheel bolt pattern the same as 2JZGE (JZA80) ? and i can therefore use a 2JZGE flywheel ?
    MA61 W58 with 2JZGE Bellhousing fitted - If a 2JZGE flywheel can bolt onto the 1JZGE, do i then simply use a JZA80-W58 push style clutch kit ? (pressure plate, clutch etc) as the W58 spline / fork etc are all the same ?
    cheerrrrs
    -coFF
    Default Re: Combining a 1JZ-GE (N/A) and a early version W58
    Fleet message to the Admiral, the answers to your mini bank of questions are all yes!
    Done that same conversion 1JZ-GTE VVTi into RA23.
    I used 2JZ-GE flywheel 2JZ-GE Bellhousing. W58 from Supra. Clutch and pressure plate was a HiLux HD unit from local brake and clutch joint.
    cheers Chuck.
    MS51Crown Coupe,
    West Australia
    Thanks Chuck,
    Was hoping that would be the case,
    I was just unsure if the non-turbo GE models of 1JZ/2JZ used the 8 bolt fly design or the 6 bolt considering they are not as powerful.
    Also i was unsure that using an 80's gearbox VS a 90's gearbox (albeit both W58) would matter at all ... im aware of the strength differences and slightly different ratios, which dont bother me as its non-turbo.
    Hopefully all goes smoothly. i think ill order a 2JZ-GE clutch kit from the USA with a flywheel etc . (lol @ Australian prices still)
    Yep, as said will all bolt up
    2JZGE flywheel and clutch = tick
    2JZGE bell housing = tick
    W55, W57, W58 (from any model as far as I know!) = tick
    Wilbo's JZA80
    Wilbo's JZZ12
    West Australia
    <3 u Wilbo!
    xx
  1. W58 Version Comparisons
    By medwin46 in forum Tech and Conversions
    Last Post: 06-03-2019, 10:02 AM
  2. Which Version of 1GGZE i have?
    By CHB in forum Tech and Conversions
    Last Post: 15-04-2009, 06:25 AM
  3. Wolf 3D version 4
    By superchargerking in forum Tech and Conversions
    Last Post: 21-09-2008, 03:11 PM
