Mic, many valid points there. The theory behind the vacuum is that the shaft has inertia. It goes at 80000 rpm, then suddenly the air going into it is cut off almost completely (throttle body closes), and so, it takes time for the turbine to slow down naturally. During this time, it is going to suck air, as it is moving faster than the air can push. When there is minimal air and it sucks hard, you get a vacuum in the exhaust manifold. This is only momentary, but enough to suck the oil. Go and check out a few dynamics text books on inertia, and some on centrifugal fans, and something on pressure differentials, it will all become clear then. Now, the BOV setup will relieve the pressure in the intake, before the throttle body, allowing the turbo to continue spinning longer, and creating more vacuum in the exhuast. If a plumback BOV is used, the turbine wheel will suck air from the intake, before the TB, into the exhaust manifold, relieving the pressure differentials on both intake and exhaust, which allows the turbo to safely keep spinning, reducing lag on gear change, and greatly reducing the vacuum effect on the exhaust turbine.
Hope this helps to explain things better. But you are right, from what is known, that extra oil pressure wont be helping anything.
as has checking that the size of his PCV system is appropriate.
cut a whole lot of wires under the bonnet, i've tryed to fix it up, but it just stalls constantly, the whole conversion is gettin re-wired over the next week, - new engine loom / fuse box - the lot.
