Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 83
Thread: Stock 4AGE Smallport Turbo Choice please
    Default Re: Stock 4AGE Smallport Turbo Choice please
    possibly lurking behind the BEAMs 3SGE, the 3SGTE, the 18RG, the 18RGT, the 20v, the single T 2J and pile of UZs
    Jul 2007
    lol you nutter
    All will be revealed, but currently weighing up SC versus T on a 4A (20v) for 250hp (flywheel)....razor sharp response is vital so may even be better off going 7A bottom end and 9000rpm?
    Jul 2007
    If you value response above all else I would suggest a 9A stroker with a 20v head and a twinscrew. but that is going pretty extreme 7A bottom end is easy enough to do though.
    new turbos are pretty epic. harreh was able to get his borg warner up to 23psi at 3500rpm the other day. that's a turbo that is capable of making 250-300kw, sitting on an 8:1 bigport 4A !!
    You know me Vito, i don't get out of bed for anything less than extreme
    In truth though, that is exactly the setup i was considering....i haven't started the 20v head on 7A block how to search yet but i'm sure there's plenty of info out there and Baz with all the required parts?
    Jul 2007
    It's all fairly straightforward build-wise, the only hard part is the hit on the wallet i'm up to ~$8000 in parts You dont need to spend that much of course, but it's pretty easy to get carried away lol. And I didn't even opt for the dry sump!
    yeh that's hefty....i'm coming form the UZ though where everything was pretty much x2 though remember...i throw my receipts away, i just don't want to know (plus the missus can't find them then )
    Jul 2007
    Yeah look in reality even my full retard build is still not that much in the grand scheme of things when you compare it to rebuilding an RB26 or a 1UZ something haha :/ at least there is only one head/manifold/turbo etc to spend on for a 4A.
    you can get a 6.2L SCAT stroker kit for an LS1 for like 3K you know
    some other food for thought - with E85, 14:1 comp and the 9A kit, I wouldn't put ~200rwkw N/A in the realm of impossibility....
  9. #39
    I'd be happy with a responsive 160rwkw...and as good as FI can be it is still hard to beat n/a for throttle response....imagine the noise!!
    Jul 2007
    Mild turbo 4A, angry N/A 9A or blacktop beams. There are plenty of ways to go about it
    Also I don't need to imagine the noise https://www.youtube.com/watch?v=EOaWgek7Owc
  11. #41
    Yes please
    Junior Member Grease Monkey rick q's Avatar
    Thanks one and all for your input.
    From what you've said, it sounds like I'll be on the right track with the TD04 - though I'll take the "safety option" of some 8.9:1 GZE pistons and try to bump the compression a little above that.
    Cheers ..... Rick Jones
    Fraser Clubman
  13. #43
    Dec 2012
    Each to their own I suppose, but regardless of turbo choice, you could do no better than a factory built smallport as hardware. As bullet proof as bullet proof gets and the C/R is perfect out of the box for what your looking to do.
  14. #44
    Can you still get a GZE short block from Toyota by any chance? Anyone tried Mal the magician here in Canberra?
    Junior Member Conversion King
    May 2010
    Yep they are still available, Castle Hill Toyota can get them, so I don't see why Mal can't.
  1. 280rwkw smallport 4age turbo setup?
    By Shifty in forum Tech and Conversions
    Last Post: 09-03-2011, 01:10 PM
  2. 3rz turbo choice
    By sammyp in forum Tech and Conversions
    Last Post: 11-06-2008, 03:37 PM
  3. turbo choice for 3gste
    By bje10s in forum Tech and Conversions
    Last Post: 31-01-2008, 11:15 PM
  4. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
