Page 8 of 11 FirstFirst ... 678910 ... LastLast
Results 106 to 120 of 159
Thread: Wakefield Park Track Day - Friday 8th of August!
  1. #106
    Jul 2007
    Default Re: Wakefield Park Track Day - Friday 8th of August!
    Iirc I paid $50 per night the two times I've stayed at the track
    website says it's $60 per night so either they've increased the rates or my memory just sucks
    http://www.wakefieldpark.com.au/faci...e/accomodation
  2. #107
    Feb 2010
    I'm in, HAHAHA VITO HAS GOD MODE
  3. #108
    Feb 2010
    Oh, not the pelican. Well wherever we're staying, I need Thursday and Friday if possible
  4. #109
    Oct 2009
    Yeah Garth, will stay Friday;
    Can I pay cash?
  5. #110
    Oct 2009
    Breather setup done
    No baffle underneath as I couldn't find my grinder to cut any alloy, not that it would of mattered as the argon bottle is reading dead empty.......will see what happens lol Paint didnt work as well in red, fuck it, motor will probably blow up anyway.
    Will need to bolt that on, fit new pads, another quick bleed, pour in some HPR30 and we are good to go.... might try a cold start on Thursday morning too.
    Not sure if my tune will total the engine, have booked the car in for teh dyno but he is busy till next week. Have pulled some timing (33deg max for a 4AGE sound ok?) and tuned in some flames and bangs for WP shenanigans.
  6. #111
    Oct 2009
    Started first hit this morning, was like 0.5c, my cold start tuna skills are strong!
    Wont be doing the pads, the instructions specifically recommended not doing it on the street.
    Cam covers and tank are mounted, it does blow out some oily misty shit out of the fitting, didn't fill the tank during tonight's testing but at some stage I'm going to have to baffle it.
    Put two wheels on the back, looks dodgy as fuck so I'm going to run with that!
    Might have to be careful with the straps as they will be anchoring off the rear quarter above the tyre lol
  7. #112
    I have a new hub, bearing and shaft in the front left so hopefully will be able to make a whole day! Tyres are on their last legs and pads are shot - oh and fluid is very soft - but it'll still be a bit of fun. I got all excited this week, am really looking forward to getting down there. Might be a touch cold though, anyone seen a forecast?
    Toymods Club Member
  8. #113
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    Friday 8 August Goulburn
    Summary Min 2
    Max 13
    Partly cloudy. Morning fog. Light winds.
  9. #114
    We've had minus 6 or colder for the last few mornings in Canberra........ lucky the sun cracks through early enough to start putting heat into the blacktop
  10. #115
    Jul 2007
    peak of 14deg on friday according to my phone, min of minus 1
    i can help you bleed brakes on the day garthos. i can even bring brake fluid if you're gonna be a cheapskate i have 1L of unused penrite racing brake fluid which has been sitting around unused for 6 months now, as the adub build slowed down. may as well start getting some use of it before it starts to get poisoned by moisture
  11. #116
    Jul 2007
    by the way, what time we meeting at brooks road?
  12. #117
    Oct 2012
    i hope someone posts a time sheet, be keen to know what you lads set.
  13. #118
    Jul 2007
    there is no timesheet. this is not a timed trackday. you need to bring your own timing gear
  14. #119
    Oct 2009
    Bring your brake fluid Vito, I need to do pads and a further bleed on Friday morning.
    Knocked over 300km on the motor, dropped the oil, looks like engine oil does after 300km on a new motor, no brass or chunky bits so
    Tipped in HPR30, ready to go.
    That aside, oil temps seem to be rather high. If I give it some for a minute its registering way hot and if I continue way hotter again. I had the alarm set of 130c on my new gauge and its hitting that easily. The sensor does bottom out on my sandwich plate as its twice as long as any normal oil temp sensor, I'm just assuming that's why, heat soak from metal and shit.
  15. #120
    Jul 2007
    HPR30 is fairly thick oil and may also be contributing to the oil temps. Why you going so thick on the oil? If the pressure is good with thinner stuff I say go for something like a 10/40
  1. Wakefield Park Track Day - Friday 1st of November!!
    Last Post: 11-08-2014, 08:06 PM
  2. Wakefield Park Track Day - Friday 16th of August!!
    Last Post: 28-08-2013, 11:08 AM
  3. Wakefield Park Track Day - Friday August 12th!!
    Last Post: 06-10-2011, 05:01 PM
  4. Wakefield Park Track Day - Friday August 13th!!
    Last Post: 13-10-2010, 05:59 PM
  5. Wakefield Track Day - Friday 31st of August
    Last Post: 03-09-2007, 03:57 PM
