Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 121 to 135 of 159
Thread: Wakefield Park Track Day - Friday 8th of August!
  1. #121
    Oct 2009
    Default Re: Wakefield Park Track Day - Friday 8th of August!
    My bearing clearances have been blown out, they are within the limits but no factory motor would of came with them.
    Combined with higher than average oil temps, been recommended to run a heavy weight mineral oil.
    Only just put it in, have been using some cheap as shit Cheyenne supercheap 20w-50 oil.
  2. #122
    Oct 2009
    http://www.enginebuildermag.com/2010...ate-continues/
    This sort of sums up what I've been told;
    Modern expensive full synthetic oils are great in modern cars with emissions equipment yet in older engines sans emissions you better off with an unrated oil or running something that meets an older spec yet is still loaded with the excellent additives that newer spec oils cannot have.
  3. #123
    Jul 2007
    stuff like the penrite racing oil still have zinc etc in them, but are also synthetic to help prevent oil breakdown and give better performance over a wider range of temperatures.
    anyways all that aside, if you are still getting approx 10psi per 1000rpm with thinner oil, i would use it. if the oil is too thick then it actually wont help with the bearings anyway, and the thicker it is the more heat you will generate through friction/resistance to flow
    also, didnt you get a big fuckoff oil cooler?
  4. #124
    Oct 2009
    Running the factory water/oil because people reckon they are awesome......
    Not keen on putting $80 of full synthetic in a brand new motor. Will thrash on this and see what happens.
  5. #125
    It shouldn't hurt it, i'm still running 'run in oil' on my car.
    Task for today is to replace the rear pads, and the gearbox oil.
    And pray it will start tomorrow morning. I have been fiddling with the cold start, and it is starting ok at ~15° water temp, which has been the lowest i have seen so far, might just have to park it in the sun before starting
    27.90s @ Esses Hillclimb
  6. #126
    Jul 2007
    Roundy - read this for cold start tuning tips http://www.adaptronic.com.au/forum/i...p?topic=2903.0
  7. #127
    Yeah been doing quite a bit of reading, no matter what i did i couldn't get it to start on sequential injection, only on batch, having to use VE around 100 to get it to crank at the low temps, but hey, if it works.
  8. #128
    Oct 2009
    What time at brooks road tonight?
  9. #129
    Oct 2012
    How much does it cost for you to have your own timing set up. I hear the non timed days are cheaper but not sure how much the timing gear costs.
  10. #130
    Jul 2007
    basic IR timing beacons cost fuckall. sub $100
  11. #131
    racechrono is still free isn't it?
    Junior Member Backyard Mechanic TA22 1MZ's Avatar
    Timing gear is something I need to put on the list..
    What's recommended setup that people go for these days?
  13. #133
    Jul 2007
    Quote Originally Posted by dnegative View Post
    garth is saying he wont be there till 9pm
  14. #134
    Hi guys, sorry, work's been mental busy the last few days - only doing a 3 day week is killing me. Yeah i need to help out with the kids at home tonight before moving, so won't get away till about 8/8:15. Getting Mick on the way through and aiming for 9pm at Brooks Rd, but if Greg was here he'd remind everybody that means it's usually a bit after that.
    What's everybody else's movements? I know Roundy will be getting to Goulburn around 9pm, so happy if people don't want to wait for me.
    Re timing gear, IR beacon setups are good, smartphone apps are good and often free or only a couple of bucks + a decent gps dongle at ~$60. I bought an IR setup and now also run racechrono to be able to compare laps, segments, lines etc.
    Remember to charge the gopros and pack the jacket and beanie!
    Ninja: Oh and those of you staying, i assume you're all giving me cash for the extra when you see me, given i haven't heard from more than a couple of you about it?
    Roundy, i'll msg you the rooms we have booked.
    Toymods Club Member
  15. #135
    Oct 2009
    I'll be aiming to be at Brooks at 9:15
  1. Wakefield Park Track Day - Friday 1st of November!!
    Last Post: 11-08-2014, 08:06 PM
  2. Wakefield Park Track Day - Friday 16th of August!!
    Last Post: 28-08-2013, 11:08 AM
  3. Wakefield Park Track Day - Friday August 12th!!
    Last Post: 06-10-2011, 05:01 PM
  4. Wakefield Park Track Day - Friday August 13th!!
    Last Post: 13-10-2010, 05:59 PM
  5. Wakefield Track Day - Friday 31st of August
    Last Post: 03-09-2007, 03:57 PM
