matty, i knew about your car from back when you did a billion years ago and often reference it. like with all rules your is the exception.
in regards to all the other stuff i have a built smallport (~200hp @ 9500rpm) with autronic and open ITBs that also does about 400kms to a tank cruising around and a lot whole lot less when on track (TPS needs resetting and about 30 mins on the dyno for clean up). TRDEE has been in and driven my AE86 and can provide evidence.
in regards to the original question it more a direct answer to the SIMPLEST and most straight forward result the OP wanted. while yes your's did work, you have the skills and expertise to make it work, we have no idea of the OP does or not. given the amount of work i have in my engine and using the T3 + programmable ECU and then the amount of work that went into making yours work the most straight forward and cost effect is as Dneg and myself described.
