Page 5 of 7 FirstFirst ... 34567 LastLast
Results 61 to 75 of 102
Thread: Lightened Flywheel Thread
  1. #61
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Default Re: Lightened Flywheel Thread
    Taking weight off the crank pully will help but not nearly as much as the flywheel simply because there is far more power needed to accelerate the flywheel due to the weight being further from the center.
  2. #62
    I know BRD Racing in the US make an alloy crank pully for the T series motors.
    http://www.brdracing.com/brdcatalog03.html
    Regards
    Rodger
  3. #63
    Quote Originally Posted by Enchanter
    thats true, but every lil bit counts sometimes!
  4. #64
    I think I might make myself a lightweight crank pulley for my 20v, doesnt matter which end the weights removed from right?
    Just for your interest:
    http://www.technotoytuning.com/productdetail.php?p=121
    Toyota Car Club (Qld)
  5. #65
    thanks for the links, I would go for the crank pulley because I can make it smaller at the same time
  6. #66
    dragging it up again but id be wary of going an aluminium front pulley as they do not have the rubber ring so its not a proper harmonic balancer.
  7. #67
    if by making it smaller you mean reducing the radius remember this will spin all your ancillaries run faster. which is often not a good idea.
    if you mean width ill just go back to my box
  8. #68
    New Zealand
    Smaller crank pulley will spin acessories slower, smaller accessory pulley will spin accessory faster.
    Callum
  9. #69
    hes right.
    im tired
    how far will you be revving the motor?
    if your not going much more than stock and its a daily i wouldnt consider it a very bright idea.
    you WILL lose oil pressure low in the revs
    if my 1g is anything to go by quite a bit at idle speeds
  10. #70
    Quote Originally Posted by love ke70
    How do you figure that? The front pulley has nothing to do with the oil pump.
    If you're going to make a new pulley, I'd be making a new larger one for the alternator as it doesn't need to spin as fast as it does.
    Just leave the stock front pulley and run the alternator at around 120% of crank speed.
    I also ran a 3kg alloy flywheel on the back of my engine and it was fine ..... once you got used to it.
    www.billzilla.org
    Toymods founding member #3
  11. #71
    Rubber ring in which engine's front pulley?
    The T and R series motors do not have them. Do the A series?
    I am sure that a motor which is being developed with lightweight spinning mass does not need a harmonic balancer type pulley.
    Regards
    Rodger
  12. #72
    Quote Originally Posted by Rodger
    Hi Rodger, the A series do have a rubber layer in the crank pulley. Upgrade pulleys for the 4AGZE and such don't tend to have the rubber layer though and don't suffer any detrimental side effects.
    My KE25 thread
  13. #73
    Well there you go!
    Now I'll also have to double check my 3S-G build also, I am throwing the pulley away anyway so it is just for future reference.
    Regards
    Rodger
  14. #74
    right, my bad on the oil pump front. anyone say i wasnt thinking?
    id just rather run a harmonic balancer rather than an alloy pulley. its obviously done for a reason...
  15. #75
    alright thanks bill I think I will do just that,
  1. The 1UZ Mods Thread
    By CoronaC in forum Tech and Conversions
    Last Post: 11-05-2014, 07:19 PM
  2. which flywheel
    By rob20v in forum Tech and Conversions
    Last Post: 22-03-2006, 08:36 PM
  3. 20V Lightened flywheel
    Last Post: 18-03-2006, 09:32 PM
  4. How to edit a thread title?
    Last Post: 11-01-2006, 09:53 AM
