Results 1 to 9 of 9
Thread: Corona MK2/ MS6/7/85 front suspension
    Default Corona MK2/ MS6/7/85 front suspension
    Hi all
    Can anyone answer my question, that are any of the above suspensions interchangeable??
    Ie, can i take the wisbone setup out of an ms85 crown and put it into the mx10 corona?
    Alternatively, can i put the ms85 wisbone setup into an ms65??
    Thanks Guys
    Blake
    Default Re: Corona MK2/ MS6/7/85 front suspension
    Don't know about ms85 - ms65, But neither will go straight into the Mark II. Afaik the control arms etc in the Crown bolt onto the chassis, Where as the Corona has everything mounted to the crossmember.
    Can I ask why you want to change the Corona suspension?
    Bushes etc hard to get? (I've just been down this path)
    Phil
    Quote Originally Posted by Pure_In_Sanity
    Phil
    wanted to know for the sake of 5 stud on a mx13...or alternatively getting 5 stud back on an ms65 without using 65 hubs...cos 65's r hot
    Ah, lol!
    Well ms65 stubs go into an ms55, maybe they would swap vice versa?
    I think falcon XD? stubs go onto an ms55 to give a brake upgrade and 1" spindle drop.
    Maybe that would work on the ms65.
    I just picked up a pair of hubs from the wreckers when i needed mine.
    Of course they aren't quite that easy to get hold of now
    -Phil
    I wonder if the XD stubs would go into the MX10 - ever tried that???
    Or alternatively, do the Crown stubs n hubs bolt onto the corona mk2?
    The ball joints might be the same, Definately worth a try. Might have to look at the difference in steering arms though. Altering this position may induce bump steer.
    I wonder if Cambelt or Gianttomato have tried something along these lines?
    Tasmania
    Im sure MS 65 hubs will bolt straight onto the MK2 stub axle.Another Toymodder, Gianttomato(GT) has done this conversion on his MK2.
    Cheers Brett.
    yeah but MS65 hubs are farkin hard to find, hence id like an alternative! Lol
  1. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  2. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
