If you are looking for the functions of those plugs I posted them years ago
http://www.toymods.org.au/forums/tec...to-mx83-3.html
Here are the colours of the wires and their functions on my MX83 GRANDE loom plugs from 7MGE motor to underdash plugs
White plug
yellow with brown spots___________ speedo speed sensor
brown _________________________ speedo speed sensor [make sure you earth this one]
yellow_________________________ temp sensor
black__________________________ tacho
yellow/blue _____________________ oil pressure switch
red/green [2] __________________ reverse
green__________________________ park
red ___________________________ neutral
blue___________________________ drive
light green______________________ 2
pink __________________________ L
Square grey plug
small black/white _______________ AC clutch
blue/red_______________________ FP diags
black/red _____________________ +B diags
red/black _____________________ 12v supply for speed sensor etc
big black______________________ nsw
big black/white _______________ nsw from start relay
light green ____________________ goes to purple/white in other grey plug
green with spots _______________ tccs diode
green/white ___________________ stop light switch
big black/yellow________________ power from ignition
small black/yellow _____________ solenoid 2 in transmission to cruise control ecu
green________________________ from airflow for circuit opening relay
black _______________________ from temp sensor on water inlet to start injector
Rectangular grey plug
pink__________ _______________ TE1 diags
brown/black __________________ earth
pink/green__________ _________ TE2 diags
grey________________________ VF1 diags
purple/white__________________ goes to pink. and light green in other grey plug
grey/green___________________ brown wire on abs sensor
pink/blue ____________________ grey wire on abs sensor
purple ______________________ blue wire on abs sensor
