Results 1 to 10 of 10
Thread: Slightly undersized ball joint taper - can I sleeve it?
    Jul 2011
    Default Slightly undersized ball joint taper - can I sleeve it?
    Hi, so I went to attach my t3 LCA's to my ta22 today, and realised that I made the idiotic mistake when buying them of not considering the fact that the ball joint taper was probably going to be smaller in diameter than the bore of the s15 silvia knuckles. I'm not sure what to do here. I need to use the t3 arms so that the rest of the suspension components will attach, but need to get a bigger taper? Can I just sleeve the knuckle or do I need to try and change the ball joint completely? I've never done the latter before so sleeving would be a nice option if it is safe...
    The world's slowest TA22 Build
    My no longer embarrassing DD >> The debt is worth it
    +rep if i earn it
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default Re: Slightly undersized ball joint taper - can I sleeve it?
    I had to do this when fitting Suzuki Vitara power steering into Sierras. The Sierra steering link ball joint had to be sleeved to fit the pitman arm taper. Never had a problem with it and still have one running in my Sierra which is still bashing around the paddocks after 10 years.
    If machined properly you won't have any problems.
    Junior Member Domestic Engineer Hurricane's Avatar
    ive not personally made a tapered sleeve for a ball joint but ive seen it done many time with no issues.
    ive also seen people drill the female taper out and weld a machined insert inplace with the right taper.
    if you can find a interchangable ball joint that would be the easyest option id think.
    come to think of it i have made a tapered insert that was welded into a steering arm on my 4x4. ran it for years with no issues
    cheers, dan
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
    spank that naughty.. Grease Monkey
    Aug 2010
    country Victoria
    I got a pair made for the tie rod ends on my mustang disc brake conversion , then found some on the internet in the us for much less than the slab !
    I thought about it for ages and cant see a problem ,
    The rally guys weld up steering arms all the time and re machine the hole , but I was taught never to weld steering parts .
    Remember this is a recreational activity ......
    we got toys ! 83 lo lux in matte black..... amazingly 18 rg powered , one day it will run right !
    the dinosour 90 gsx r 750 with ohlins and yoshi , and the dirty little secret 125 vespa ,4 speed and kick start
    Jul 2011
    Yeah I thought that the cast might be an issue, but I'm not gonna do it myself.. I rang up a local(ish) fabricator and asked about it and he's happy to do it for $160... Replacing the ball joints would have been an easier option but they're t3 LCA's and they do not appear very easily replaceable.
    I guess at the end of the day it's only a small change, not like the welds are going to be taking any huge tensile loads or anything.. Cheers everyone for the tips/advice
    +rep if i earn it
    Cut and shut steering arms and knunkles made of cast steel are a common thing in the drift sene and ive never heard of one breaking. There are different methods in welding cast with pre and post heating and cooling times. normally cooled slowly in an oven or buried in lime.
    ive welded the case that steering arms are made of before without any issues on 4wds.
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Do s13 bjs fit into the t3 lcas I woulda thought swapping them would be your easiest and cheapest option take u 10 mins on a press and new bjs can be like $50
    Apr 2007
    Quote Originally Posted by Hurricane View Post
    As you have said & even some racing & rally guy's from what I have heard have done welding to steering arms etc, but In saying that I would not feel comfortable myself in doing it or driving a car with welded steering arm's etc & good luck getting it Engineered ..
    Jul 2011
    They're not going to be cut, plan is to get an insert machined up as a nice snug press fit, push it in and weld. The fabricator is experienced with cast and it should be very close to undetectable.. I don't get why people see inspection/engineering as such a tough thing to deal with, they've been nothing but accommodating to me so far! If this little mod is going to be a deal breaker, I doubt I'll have much luck with all the actual major mods that are happening
    +rep if i earn it
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    your insert idea sounds good but ball joints are extremely cheep, go down to your local auto parts store and ask for an s13 bj and a ta22 one or whatever t3 happen to use in their lcas, compare the dimensions, if they are the same O.D. and height from lip to circlip groove then you may save yourself alot of coin and unnecessary hassle
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  1. Anyone had to chase a ball joint for a soarer?
    By Nicke25 in forum Tech and Conversions
    Last Post: 11-01-2011, 01:25 PM
  2. Ball joint compatability
    By joshz18 in forum Tech and Conversions
    Last Post: 02-12-2009, 04:17 PM
  3. How to use ball joint separator
    Last Post: 06-11-2009, 07:14 PM
  4. GZ20 ball joint size
    Last Post: 27-07-2007, 12:52 PM
  5. Steering arm and ball joint problem
    By gtv_86 in forum Tech and Conversions
    Last Post: 08-08-2006, 06:36 PM
