Page 1 of 13 12311 ... LastLast
Results 1 to 15 of 185
Thread: MA61 Part Numbers & General Infomation
    Default MA61 Part Numbers & General Infomation
    MA61 Part Numbers & General Information
    BUSHES
    Noltec: 02 9980 9777
    http://www.noltecsuspension.com.au/
    MA61 Noltec Urethane bushes
    NOTE: Prices are over the phone quotes from Noltec Direct, and are JUST A GUIDE
    Control Arm Inner (FRONT).........N51665 $34+ tax
    Radius Arm (FRONT).................N81664 $37+ tax
    Control Arm Inner (REAR)...........N61666 $70+ tax
    Control Arm Outer (REAR)..........N61667 $82+ tax
    SuperPro Urethane Bushes:
    http://www.bac.com.au/
    NOTE various prices available, depends who you speak to. below are JUST A GUIDE
    Front Control Arm Lower - Inner Bush..........SPF0509K $24.5 Use original shell 2B,2T
    Front Strut Bar To Chassis Mount...............SPF0307K $25.5 4B
    Front Sway Bar Link Bush Kit.....................SPF0903K $13.5 8B
    Front Sway Bar Mount To Chassis Bush......SPF1450K $10 Measure bar dia 12-30mm available 2B
    Rear Control Arm - Inner Bush.....................SPF1213K $55 [IRS] 8B,4T
    Rear Shock Absorber - Lower Bush.............SPF2178-16K $9 2B
    Rear Shock Absorber - Upper Bush.............SPF2755SK $10 4B
    Rear Sway Bar Link Lower Bush.................SPF0280K $15 4B,2T
    Rear Sway Bar Link Upper Bush.................SPF0903-4K $9 4B
    Rear Diff X-Member To Chassis Mount.........SPF2926K
    Rear Cross-member To Chassis Mount........SPF1447K $115[Listed under Supra but assume is same as IRS Celica 4B,2T
    Nolathane
    http://www.redranger.com.au/
    Rear Sway Bar Mount to Chassis Bush.......#42330 $21**
    **Needs slight modification of the swaybar bracket. Click here.
    BRAKES
    Rotors:
    DBA...........MA61..........Z32/R32........R33 GTST........R33 GTR
    Front...........#146............#909.............# 4963..............#4928
    Rear............#717............#908.............# 908................#929
    RDA...........MA61..........Z32/R32........R33 GTST........R33 GTR
    Front
    Rear...............................#908........... ..#908
    Pads:
    EBC Greenstuff
    .............MA61..........Z32/R32........R33 GTST........R33 GTR
    Front....DP2456
    Rear .....DP457*
    *Blackstuff
    DRIVELINE
    Auto to Manual conversion
    For a list of compatible parts to use for this conversion, click here.
    The Toyota Axel Database by the famous Norbie.
    Wheel and Gearing Calculator where you can also find out what speedo gear drives you need to have an accurate speedo.
    For a correct speedo with a 3.73 diff ratio with stock wheels (ie 195/70 R14 or 225/60 R14), you'll need an 11 start worm drive gear with a 32(11) driven gear.
    Where to find second hand diff ratios.
    SUSPENSION
    RA60 strut install website with a bit of detailing of the differences between the RA60 strut and MA61 strut
    Sway Bars
    *Please note that the rear sway bar mounts on the crossmember are prone to breaking after upgrading your swaybar. I strongly recommend re-inforcing these brackets before you install some new sway bars. The stronger sway bars bend this bracket up and down over bumps and weakens it. They then eventually snap in half. Clicky
    Addco:
    Front: #ACO-375 : 28.575mm
    Rear: #ACO-745 : 19.05mm
    $298US Rabid Chimp
    Whiteline:
    Front: BTF-76 : 27mm : $213
    Front: BTF-76Z : 27mm [Blade Adjustable]
    Rear: BTR-21 : 19mm : $171
    Rear: BTR-21Z :19mm [Blade Adjustable]
    Strut Bars
    935 Motorsports:
    Front Adjustable Strut Bar US$149
    Rear Adjustable Strut Bar US$149
    Rear Adjustable Carbon Fiber Strut Bar US$175
    MK2 celica supra front and rear stut braces thread!
    Making custom strut bracethread
    Adjustable Strut Tops
    Noltec:
    Camber/Caster Adj #N44027 $350
    Kmac:
    Camber/Caster Adj #761316K $400
    Cusco:
    Camber Adj US$229 [935 Motorsports]
    King Springs
    ................Low............Std
    Front......KTFL-31......KTFS-31
    Rear.......KTRL-27......KTRS-27
    Shocks
    *This is an Excel file of all known shocks compatible with the MA61 chassis. Included are KONI part numbers and details.
    Download Here
    Rundown of front struts increasing stiffness.
    KYB - GR2 (only girls use these)
    Koni - Red (from what I've heard... stock-style replacement)
    Tokico - HP (logical low-cost solution)
    Koni - Yellow (just... hump my wallet please)
    KYB - Select-a-Ride (What Joe runs in his race-car!)
    KYB - AGX (the mr2 inserts spacered to work... lots of happy customers on these)
    Rundown of rears, same gig.
    KYB - GR2 (only wussie girls use these)
    Koni - Red (from what I've heard, again)
    Tokico - HP (eh... go gas-a-just or AGX)
    KYB - Gas-a-Justs (easy to acquire and work gooood IMO)
    Koni - Yellow (still humping my wallet? goood)
    KYB - AGX (the focus rear's we've seen good luck outa, came in the groupbuy)"
    KYB
    Front: MR2 SW20 [Wes's Write-Up, externally adjustable]
    #765016
    Rear: Ford Focus 04 [Wes's Write-Up, externally adjustable]
    #741067
    --Please note that the above two shocks need some modifying to fit. Please follow the links above.
    --These shocks are available through 935 Motorsports Here for US$325.
    Front
    #365076 - $168.18 +GST
    Rear
    #343042
    KONI - Great read on KONI shocks here
    Please note:
    The 'Red' or 'Yellow' after the shock description denotes the shock absorber stiffness.
    Yellows are stiffer than the Red shocks.
    Please refer to here to check if the shocks in question are externally adjustable or just standard adjustable. Special thanks to Wilbo there.
    Front: MR2 SW20 Rears. KONI Yellow#
    #8641-1221 Sport
    Rear: E36 M3 Rears. KONI Yellow
    #8240-1115 Sport*
    -This combination seems to be the best for a street/weekend race setup. 935 Perfomance have these for sale in the USA for AU$900 shipped.
    #Gland nuts supplied are 1.5 thread. Required gland nut thread is 1.0 to suit xA6x strut. Koni part number for correct gland nuts is: 7325-01-0021, $40 the pair.
    *You have to replace the lower 'eye' bushing in the shock with
    SPF2178-16K from Superpro, to work with the MA61 suspension.
    Front: xA6x Fronts. KONI Yellow (Fulcrum Suspension $600)
    #86-1991 Sport*
    Rear: xA6x Rears. KONI Reds [not in production?]
    #28-1131 Sport*
    *You can still buy the #86-1991 Here and the #30-1599 Here from Classic Garage in America.
    Front: TOYOTA CELICA SUPRA 84/85. KONI Reds[listed on Whiteline website]
    #86-2328 Sport
    Rear: RAV4 KONI Reds
    #30-1599 Sport
    Rear: VB VP Commodore Reds
    #80-2597
    GABRIEL
    Front
    #G44939 (Note this is the wrong part number, although no one will admit it. You can get Delco (rebadged Gabriels) shocks off eBay from Ultracheapauto.com)
    Rear
    #81440
    OTHER MANAFACTURE PART CODES
    Mackay Rubber:
    - New Pedal Rubbers - #A1281 $5ea Clutch and Brake only. No Auto Pedals
    - Engine Mounts (rubber) - #A5196 - ~$80 a side (genuine is $160) (listed under MX73, no MA61 listing) ** $110 for the pair at Repco
    - Gbox mount (rubber) - #A5197 (Don't know price) (listed under RA60/SA63/RA65, no MA61 listing)
    Repco:
    - MA61 Balljoint - TBJ314 - $48 each
    5ME Belts:
    - A/C - 13A0990 - $15.99
    - Alt - 7PK0920 - $32.79
    - P/S - 13A1420 - $19.99
    NGK Plugs
    - BPR6EY (5ME) - $26.34 (for 6)
    - BCPR6ES (7MGTE)
    - BCPR7ES (7MGTE, 1 heat range colder than stock)
    Top Gun Leads - TG6032 (5ME) - $64.99
    Camelot:
    - MA61 Tie Rod Ends - TE-641R
    Gates:
    - Upper Radiator Hose for 5me to 5mge conversion - EF Falcon 1994 onwards - PN# 05-0917
    VENDOR LINKS
    RDA Brakes www.rdabrakes.com.au
    DBA Brakes www.dba.com.au
    Noltec Suspension www.noltecsuspension.com
    Addco Suspension www.addco.net
    Whiteline Suspension www.whiteline.com.au
    SuperPro Bushes www.bac.com.au
    Nolathane Bushes www.redranger.com.au
    K-Mac Suspension www.k-mac.com.au
    Cusco Suspension http://www.cusco.co.jp/english/e_cont.html
    KYB Shocks www.kyb.com.au
    Koni Shocks www.koni.com
    King Springs www.kingsprings.com
    Techno Toy Tuning www.technotoytuning.com
    Rabid Chimp www.rabidchimp.com
    935 Motorsports www.935motorsports.com
    Import Bitz www.importbitz.com.au
    Forcefed Performance www.forcedfedperformance.com.au
    Castle Hill Toyota www.chtoyota.com.au
    TOYOTA PART CODES
    Clip Door Trim FJHJ6 (Clip that holds door cards on) .......................67771-22010 $1.15ea
    Retnr RN 30 4# (Lower bush seat on the sway bar end link Fr) .........90948-02015 $1.50ea
    Clip Molding FJ8309 (Plastic clip used to screw stuff into) ...............90189-05012 $1.25ea
    Ring Lamp MS112 (Plastic Sphere clip for indicators) .....................81219-14040 $2.25ea
    Rear Spring Lower Seat RH .................................................. .......48258-22041 $25ea
    Rear Spring Lower Seat, LH......................................... .................48258-22050 $25ea
    O Ring V292 (Oil filter bracket to block O-Ring, 7M-GTE).................90301-68005 $4.85ea
    Rush Shift RN7808 (White Cap W5x Shifter)...................................33548-31010 $8.64ea
    Seat MTM LVRLN46811 (Green Seat W5x Shifter)..........................33505-35020 $19.50ea
    7M-GTE Accordian Hose .................................................. ..........17882-42012 $93.95
    Oil Filter (All M series motors) .................................. ...................90915-YZZD2 $19.85
    Grommet (4 brake lines where they go through side of engine bay)...90480-22210 $4.05ea
    Longlife Coolant 4L (Toyota Red)...................................... ............08889-80086 $34.75ea
    Hose (5M Lower Radiator Hose, EX Japan).................... ...............16572-41101 $16.25ea
    Hose (7M Upper Radiator Hose)...................................... .............16571-42010 $16.25ea
    Liner Clip RZN169 (Splash gaurd screw in clips)..............................90189-06220 $1.00ea
    Hose MA70R (PCV hose to accordian pipe)...................................12264-42010 $25.25ea
    W57/58 extension housing oil seal ............................................... 90311-38032 $19.36ea
    Front grille clips (the little clips that break)......................................90467-12008 $1.85ea
    Plug Manifold CM8301 (Diff filler plug).................................. ..........90341-18006 $5.80ea
    Speedo Worm Drive Gear, 11 tooth............................................. ..33481-22020 $57.15ea
    Speedo Driven Gear, 32(11) tooth............................................. ....33403-19255 $52.95ea
    Washer, Plate (Sits under the axel shaft nut, clicky).......................90201-20329 $4.80ea
    MA61, RA65, Rear carpet .................................................. ........ 58570-14231-20 (Black)
    Head Lamp Protectors (Rubber strips)
    Left hand side.............................................. .............................. 54126-14011 $128.oo
    Right hand side.............................................. ............................ 54125-14011 $128.oo
    Clips ( 4 per side )................................................. ........... .......... 90467-07023 $ ??
    Final Gear set (Diff) - "F" crown & pinion
    4.100:1... 41:10 teeth............................................. .... 41201-39575...
    3.909:1... 43:11 teeth............................................. .... 41201-39585...
    3.727:1... 41:11 teeth............................................. .... 41201-29298...
    3.583:1... 43:12 teeth............................................. .....41201-39467...
    Power Steering Rack Kit
    P/S pump.............................................. .................... 04446-22010 $62.00ea
    P/S rack master kit............................................... ...... 04445-24012 $158.00ea boots extra
    #NOTE: Rack master kit includes the control valve overhaul kit
    INTER-CHANGEABLES
    Most xA6x Parts
    MZ10 is almost identical to the MA61
    MA70 1" Brake Booster and Master Cylinder
    FZJ80 1" Braker master cylinder, direct bolt in (tbc)
    MA61 Auto crossmembers are a perfect fit for fitting the A340E gearbox
    MX73 LCA's are exactly the same.
    CONVERSIONS, UPGRADES AND GUIDES
    Ed's MS65 Front 5 Stud Hub Upgrade
    Sam's RA65 Struts and Steering Arms Upgrade
    Sam's GH Sigma LCA Install
    Sam's Changing valve shims on a 7MGTE
    Sam's Rear Parcel Shelf Guide
    Sam's Front Strut Brace
    Cruzida's xA6x Skyline Brake Upgrade
    Michael's 5 Stud Conversion
    Norbie's MA61 Suspension, Brake and Wheel Upgrade
    Norbie's 6 speed conversion, V160
    Andy's 7MGTE Conversion
    Joorsh's 1JZ / 2JZ into MA61 / MZ10 Guide
    Dave's R154 Install Write-up
    James' Cruise Control Install Write-Up
    James' How to build a Tacho Adapter
    Tim's AU Falcon Thermo Fan Install
    Rob's DIY Rear Spring Replacement Guide
    Rob's DIY MA61 S13 Strut Tower Brace
    Rob's 5ME Air Pump Removal
    thomasbl: Problems With Installing a W5x shifter
    Enchanter's 5ME to 5MGE Conversion Guide
    Peter's How to, Tacho Booster
    Bbaacchhyy's old 5 Stud conversion thread
    OTHER RANDOM TECH LINKS
    Rose jointing LCA's
    Toyota gearbox ratios
    Differences between xA6x rear swing arm mounts
    Continued a couple posts down...
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    Default Re: MA61 Part Numbers & General Infomation
    Thanks for the post... That will be good info for those MA61 owners...
    Cheers.
    EBC Green fronts for MA61 - DP2456
    SHE LIVES!
    Just a note, but I wouldn't be putting up that you can replace the 15/16th master cyl with a 7/8 one.
    I think you'll find thats highly illegal.
    Unless the 7/8th is a typo?
    Well done on the list. Thats going to be more than helpfull.
    First post passed 20000 characters, continued here...
    Thanks to Cruzida, 7MA61, Viper, Stefan, ed_jza80, Joorsh, Norbie, Michael, Yian, Tim, Wilbo, Chris, James, thomasbl, Peter, GA61XX and anyone I’ve missed, without the info that they have provided somewhere on the forums this list couldn’t have happened.
    This is just a list i have compiled of the infomation that i have gathered. Had it laying around for a little while and thought i'd better post it up. If the Mods think it should be in the FAQ's then by all means move it.
    If anyone has any information or can fill in the gaps above (eg the pads and RDA rotors), let me know and I will enter it in above.
    Sam
    Updated it a little bit. Still need all the other infomation missing. I spose i should hunt it down myself but i cant be bothered/don't have the time at the moment.
    I have the part numbers at home for EBC pads - MA61 rears and R33 GTSt fronts. I have Greenstuff up front but they only make Blackstuff for the rears. Anyway shoot me a PM to remind me and I'll give you the part numbers when I get home.
    Mackay Rubber makes new Pedal Rubbers
    A1281 is the number. They aren't 100% tight like the factory ones, but useable none the less. $5 each for clutch and brake (nfi about auto)
    Rear spring lower seats are 48258-22041 - about $25 a side.
    Thats all I can offer from here.
    whoa! impressive stuff Sam I will post rear main seal replacement part number, and other numbers for 5m
    EDIT: Tim aka ZZT231 should take credit for the AU thermo fans I think, also it's James' not Jame's
    better link for the cruise article: http://www.toymods.net/forums/showpo...&postcount=740
    TAS
    Smalll radiator hose is available in the right size to slip over the bottom coil as an alternative... well, that's what a shop did to my springs years ago.
    Norbie, you have a PM
    Thanks Cruz, thats still pretty good info there. Every little bit helps
    Thanks Viper, looking forward to the part numbers.
    Yes, thats Tims. Silly me, im getting peoples names mixed up now. Never was good at names
    And a big thanks to that link to the cruise control article.
    And cheers Stefan aswell. Im sure some people will find that useful. I know i sure would if i had some radiator hose laying around and had perished lower seats.
    Noltec:
    Adjustable strut tops # N44027 $350
    Can anyone confirm that this is the part number for MA61 camber/castor tops? I ask this because according to the Noltec catalogue:
    CELICA TA22,TA23 ‘70-77
    Strut - top mount (Urethane- street) F 2 ■ N44027 1 Camber/caster adjustable
    Strut - top mount (Solid-clubsport) F 2 ■ N44027S 1 Camber/caster adjustable
    SHE LIVES!
    TAS
    I can tell you that xA6x Celica strut top bolts are offset 60* compared to xA6x, xA4x & I asssume xA2x Celcia ones - so if the decription is correct, they won't suit your car.
    There are also T3 tops to consider, but they don't work with stock upper hats (need coilovers). Or KMAC if you don't mind them being flimsy
    W5X Alloy Shifter Bushes
    White Cap # 33548-31010
    Green Seat #33505-35020
  1. JDM AE86 & Euro AW11 part numbers & part diagrams
    Last Post: 01-07-2006, 12:46 PM
  2. SW20 Complete Suspension Kit - Part Numbers?
    Last Post: 25-04-2006, 09:22 PM
  3. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 11:31 AM
  4. T-50 part numbers
    Last Post: 31-01-2006, 05:59 PM
