Page 2 of 13 FirstFirst 123412 ... LastLast
Results 16 to 30 of 185
Thread: MA61 Part Numbers & General Infomation
    Default Re: MA61 Part Numbers & General Infomation
    How could i forget! Thanks Wilbo
    JZA80 Convert Backyard Mechanic
    Ok, i've just been looking into Koni shocks for the MA61 through a friend that can get them from the local distributor and have some interesting results.
    According to the distributor Koni Sports are still available for the front and rear. I was even able to get pricing for them. Interestingly enough they work out to be over $100 cheaper all round than going with the MR2/E36 M3 options, and obviously bolt right up.
    What I'm trying to work out is, why would people be looking at the MR2/M3 option if the MA61 Koni's are still available? Has anyone actually tried ordering them to be told that Koni can't do them? I don't have the money at the moment for either option so I can't exactly place an order myself to find out
    Oh, and to clarify the part numbers in the Koni catalogue show as 86-1991Sport for the fronts and 30-1559Sport for the rears. The fronts are the same as a number of other Celicas and interestingly the AE86. The rears are the same as the Cressida MX32,62,73 and the RAV4. There is NO listing for Koni Reds for the RAV4 in the catalogue....
    Yeah I tried ordering Koni's a few years back and my local Koni retailer told me they just weren't available for the MA61. Perhaps they've updated their catalog since then after discovering some of their other products are compatible?
    Doubt it, I got this catalogue about 3 weeks ago and it's dated 2003
    Oh well, was hoping I could save a bit of cash but looks like I might not be able to. When I have the cash I'll probably try ordering them anyway and see what happens
    I'd +rep you but it won't let me yet
    This is good news ma61turbo I'll have to make sure I get the cheaper ones
    Garage Queen Automotive Encyclopaedia ZZT231's Avatar
    Quote Originally Posted by ma61turbo
    The main reason people are looking at the MR2/M3 option is that they can be adjusted externally (on the car) while the recommended MA61 and Rav4 rear are internally adjusted (have to take them out to adjust them).
    The parts numbers are correct just Koni Australia doesn't recognise they exist, you can order them through the states though.
    It'll be interesting to see what arrive for my suspension , and after confirming fitment I'll add the part numbers I have lol.
    If in doubt power out
    Quote Originally Posted by ZZT231
    Hrmm, I was under the impression that the Reds were the off car adjustables and the yellows on car.
    Well, the catalogue is useless as far as that goes. Doesn't say either way, but I gather that seeing as it only mentions the Yellows as adjustable then the reds definately aren't. No point going with the MA61 part numbers from the states, would work out to be a very similar price to the MR2/M3 option locally and get the added bonus of on car adjustable.
    EDIT: After further investigation it seems like it all depends on part number as to what is adjustable or not. Reds come in adjustables as well, both internally and externally.
    Quote Originally Posted by RObErT_RaTh
    Well, going by the links in the first post, you'll only be able to get Yellows for the front and reds for the rear, from the states. Using the Classicgarage links, #86-1991Sport(front) are $274.40/pr and #28-1131(rear) are $52.96/ea. That's $380US prior to shipping etc. Not bad really, would be a decent option for you I reckon. And as has been said both of these are off car adjustable.
    FWIW my Koni yellow's are externally adjustable, not sure if that applies to all yellow's though?
    See my edit above...
    Some reds can be externally adjusted also depending on the type of car. The koni recommended shocks for the MA61 fronts a RAV4 rears are internally adjusted and they are yellows as I've got them on the car.
    This is a confusing subject, shocks is. I did a fair bit of research and found that the Yellows are in-car and Reds off-car adjustable. Seems some reds are in-car adjustable acording to Tim. Seems it might take a while to get to the bottom of this subject about Reds and Yellows.
    The reason the Koni Yellow MR2 front and E36 rears is such a good combo is that they are:
    1. Both in-car adjustable
    2. The E36 rears are a really stiff spring. The softest setting has been said to be like the hardest setting on MA61 specific adjustable shocks. So, they are good track shocks.
    3. Easily acquired. Well from the US but your not going to get them in Aussie i dont reckon.
    The only downside is your going to be parting with close to AU$900...
    This is a confusing subject, shocks is. I did a fair bit of research and found...
    It really shouldn't be that hard....!
    (http://www.koni-na.com/pdfcatalogs/2005applguide.pdf)
    We all know that the MA61 front part numbers are 86-1991 (sports), which are yellows. Looking at konis table we can see that these are
    -Twin Tube Hydrulic
    -Standard Adjustiable (NOT externally Adj)
    -McPherson strut Cartridge
    And if you did some more searching...
    (http://www.koni-na.com/pdfcatalogs/K...ortCatalog.pdf)
    -Twin Tube Hydrulic
    -Rebuildable
    Yep, all this information is in the Koni catalogue that I have. As I said, it depends on the part numbers, not whether they are Red or Yellow. That just seems to denote the strength of the dampening, ie the yellows have a much stronger dampening action than the reds.
    +rep Wilbo
  1. JDM AE86 & Euro AW11 part numbers & part diagrams
    By parrot in forum Tech and Conversions
    Last Post: 01-07-2006, 11:46 AM
  2. SW20 Complete Suspension Kit - Part Numbers?
    Last Post: 25-04-2006, 08:22 PM
  3. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 10:31 AM
  4. T-50 part numbers
    Last Post: 31-01-2006, 04:59 PM
