Results 1 to 15 of 17
Thread: Dizzy getting hot!!!
    Default Dizzy getting hot!!!
    After doing my conversion, i found a smell like a burning smell coming from the engine bay, i pulled the dizzy off and i notice that it was melted at the bottom, so i took it for a drive (AKA THRASH) then i came back and found that the dizzy was melting and dripping on to my extractors, i did put the heat wrap sheild stuff on it but the plastic just heats up then it fall off, i was thinking about a shield but don't know what material to make it out of, any suggestion. OH yea it's a 4age in a AE71
    Default Re: Dizzy getting hot!!!
    mmmmmmmm do u have a picture of the bay, so can c where it is ?
    Western Aus
    well, needless to say, it SHOULDNT be doing that.
    sounds very much to me like its shorting out something shocking.
    Eldar.O.
    uis it pinging or anything?
    Sure the ballast resistor hasnt collapsed?
    S.A
    i no what you mean m8 !!!! i have melted one before too !
    put some heat wrap around your no.1 header and make up a shield for the dizzy if there is room .
    stainless or some of that purpose built heat schroud like on the xr6 turbo will do !
    i have seen this a few times,
    does you dizzy have a metal heat shield attatched to it? it should go between the cap and exhaust primary #1 - this will hel you out a lot.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    hmmm i will be having the same problem with my turbo manifold sooooo close to it. Any thing else which will stop it melting? Certain metals or should i just take it off an put a CAS on there.(Microtech ecu)
    ceramic coat the manifold
    make sure you dizzy has a heat shield
    put another heat shield between the two things
    duct some air to the dizzy
    www.vicdrift.com
    Just make sure it's heat shielded, my dizzy is tucked right next to my turbos and right under the intercooler pipe and thats factory.
    I don't think it is electric and the car is running fine it doesn't miss or nothing, i think the extractor must be thinned wall so they produce a shit load of heat. the dizzy doesn't have a heat shield so i might try to make one, here's the pics
    You can see where the plactic has dripped on to the extractor, so yea
    Junior Member Grease Monkey BigBadBenny's Avatar
    savtec,
    either ceramic coat the extractors, or heat tape them, I've found that foil stuff pretty bloody useless. and put a heat sheild on your distributor, it's supposed to have one, I can even see the screw holes where it's ment to be.
    Regards
    Benny
    If you look at the pics there is a small bolt hole visable.There should be a heat sheild bolted through it .
    Lack of heat shield would be the main culprit. Fit one.
    I have also seen a 4A-GE dizzy MELT, due to the numb nuts backyard installer, who got the cooling system arse about!
    cheers Chuck
    heres a good qualityy heat wrap that works, its like a woven fibre - not the most attractive, but i use it on my ma61 to protect my clutch and power steering...works well...is like a canvas colour...
    Thanks fellas i will try to make a new heat shields soon as, i didn't even know there was meant to be a heat shield on it, as it wasn't there when i got it. Thats for ya help Gav
  1. magnetic pickup in dizzy, which wire is + which is -
    Last Post: 11-05-2006, 12:13 PM
  2. Wtf. my dizzy is cracked! pics
    By Aust162 in forum Tech and Conversions
    Last Post: 16-03-2006, 05:43 PM
  3. 3t-gt - Haltech - Std Dizzy
    By 3t-RA40 in forum Tech and Conversions
    Last Post: 13-02-2006, 10:36 AM
  4. 3tg dizzy rotor button
    Last Post: 08-02-2006, 07:47 PM
