Results 16 to 30 of 43
Thread: what on earth is a 1GGPE????
    Default Re: what on earth is a 1GGPE????
    Quote Originally Posted by GTtwin
    Think about combining that engine with GZE bits, blown on LPG. The effective octane rating of gas would keep it well away from detonation even with a fair shot of boost through it. Or even atmo with triple mikuni's, that would sound freakin tough. A 10:1 compression 1G, whooha!
    Actually LPG in the city has been the equivillent of about 92 octane for some years now
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    actually they all have minimun standards of 102 octane.
    is there a difference in the fuels that makes lpg only the equivalent of 92 octane petrol ?
    Montrose
    92 RON or MON?
    The 'quality' of the fuel usually depends on how much propane (good, sausage fuel) and butane (bad, lighter fuel) it contains.
    Quote Originally Posted by Draven
    I recommend a look-in at the daughters while you're there
    Nahhhh... they've gone all Goth!!!
    seeyuzz
    river
    Quote Originally Posted by love ke70
    Just to clarify. The City blend of LPG is crap compared to what it used to be (Same as Country blend). The propane/butane mix is designed to be a cheap Taxi Pack fuel. A dedicated LPG tune will yield about the same result as a dedicated Petrol tune on 92 octane assuming the set up is correct and not some budget entry level gas system. You are also allot more limited in how big a cam you can run (Compared to Petrol) and how much compression you can get away with (Compared to a country blend LPG).
    As a rule of thumb you also use twice as much LPG as petrol to cover the same distance so keep that in mind when deciding how cheap it is to run Oh and rumour has it LPG will be taxed like petrol by the end ofthe year. Not sure how true that is tho.
    Quote Originally Posted by mrshin
    92 RON or MON?
    To illistrate this further take a look around the web and try find an actuall RON/MON whatever rating for LPG. Chances are you won't find one. Yes the Octane rating of LPG is higher than petrol BUT because of the inconsistances with the Blend its performance an be quite varied and of course being a "dry" fuel its allot harder on the engine.
    Heres an extract from the MSDS for the Caltex LPG (VitalGas). The MSDS is a legal document and governement regulated so they have to be accurate. Take a good long look at just how big a variance you can expect in your LPG:
    2. COMPOSITION/INFORMATION ON INGREDIENTS
    Ingredients Name CAS Proportion Hazard R Phrase
    Propane 68477-94-1 0-100 %
    Butane 106-97-8 0-60 %
    Propylene 115-07-1 0-40 %
    Butylene 106-98-9 0-10 %
    Ethyl Mercaptan (Odourant) 75-08-1 0-0.01 %
    Yep thats a 0 - 60% proportion of Butane !!!!
    agreed 110%. the trouble is it isnt regulated{or consistant} like the pulps, and even the pulps is a bit and miss at times at times as we have all had pulp that has pinged, when it shouldnt.
    Gas is great but i wouldnt be using it in a performance engine unless you are way under its limit with timing and comp.
    Quote Originally Posted by TheToyman75
    i agree, and disagree with that statement,
    yes lpg isnt as good as it used to be as manufacturers use it as a dumping ground for all the unusual by products theyve produced.
    yes, lpg will make the same power as a good petrol tune
    you can get away with more compression with any form of lpg than you can with petrol, due itsgreater detonation resistance, and also slower burn rate
    i disagree with the 100% more lpg in comparison to fuel, its closer to 30% in real world situations.
    yes, lpg will be taxed at some stage and this tax will gradually increase, but the government has stated it will never be greater than 11c/L
    realistically, LPG is only good if you pick up a car already converted to LPG
    OR
    if you do an engine conversion and need to meet emision standards
    AND
    usually when you do an engine conversion you have more power on tap, so running lpg, you end up getting similar if not better economy than you were, simply because you have more power so spend less time at WOT
    IMO anyway
    done some digging
    http://www.caltex.com.au/products_oil_detail.asp?id=179
    http://www.bp.com/sectiongenericarti...tentId=7016925
    http://www.shell.com/static/au-en/do...g_fuel_pds.pdf
    just the minimum standards advertised by those 3 companies. coudlnt think of any others to check??
    tasmania
    and you believe the government????
    maybe i should convert my 1uz to gas? petrol is dear where i live. how many people use gas here? anybody from Tassie?
    beer me!
    so with all those advantages why would anyone bother with a petrol 1G?!?!
    '77 RA28LT #2 ← 2.2L 18RG...
    i dont know
    my ke70 is running a 1ggte on LPG
    Wezelton Grease Monkey
    I think MAYBE one reason people arnt using gas is because the big jap tuners in japan dont use it, and since they are big companies making mass amounts of performance products and only use 110octane fuel.. I mean look at all the 1000hp gtr's ect. Personaly gas would be cool i think, just needs to be 100%. I do remember reading an article in HPI magazine about high horse power car on lpg, from memory it was pushing 400hp+ at the wheels so i guess it cant be all that bad. Any aussie tuners reading this thread ? Love to hear a work shops opinion!!
    Wes.
    Bitch, come over here and have sex with Charlie Murphy..
    Im Rick James bitch!
    dont mean to be rude but aftermarket wise we are as good as if not better than the japanese thank you!lol motec, autronic. and i dont think i have ever seen a serious tuner in OZ ever do anything they have learnt from japanese or anyone!
    drift guys might, but the rest dont. lol
    I got agree with mick on that one, you really do get sick of guys just copying the japs cause they thing the japs have all the answers... most of the "custom" work is up the shit but its jap so its cool haha
    KE38 - 2TG
    MS65 - 1UZ
  1. Earthing kits - myths or truths? (modem size warning)
    By Mos in forum Tech and Conversions
    Last Post: 31-05-2006, 01:38 PM
