Results 1 to 9 of 9
Thread: 91 Soarer auto trans rebuild kit
    Jan 2008
    queensland
    Default 91 Soarer auto trans rebuild kit
    Hi, I have 93 hilux 2wd that I converted to 1UZ& A341-E. It's been a good reliable ute but yesterday lost all drive in the auto. I removed the filter and found it was clogged with brown clutch debris so my question is has anybody done a rebuild on this trans and if so where is the best place to get a rebuild kit? Seems you can get a kit without the steels in the clutches, just frictions. It's the forward drive clutch that has shit in my trans which is quite common apparently. The fluid has always been a nice red colour and has no burnt smell at all, the clutch material in the filter is also unburnt. There was a noise in the trans for quite a while, like a scraping bearing type noise that came and went at times but it never bothered the operation so I was waiting for it to develope, it developed yesterday by leaving me stuck on the hwy with no drive haha. So I'm going to have a go at rebuilding this trans but don't know where to shop, any help would be greatly appreciated, thanks MICK.
    Oct 2009
    Default Re: 91 Soarer auto trans rebuild kit
    Buy a used box from a wrecker, fit a shimmed valve body, fit a cooler and service it every 10,000km and you should get a lot of km's out of it for a fair bit cheaper than rebuilding your rooted box.
    Jan 2008
    queensland
    Yeah I know what yr saying but, they are getting long in the tooth now so chances are I may get one thats well on its way to being rooted. Ive rebuilt a few autos before so I think for the cost of a master kit I will end up with a good unit, my work has provided me with a ute so I can take my time and do it properly. I have a 2800converter in there atm and will going back to standard if you know anyone interested
    Hi Mick
    I can email you the manual for the transmission if you want it. Save you looking for one
    Jealousy is a curse
    Jan 2008
    queensland
    Hey Madmont, I have an A340-E manual which seems pretty much the same as my A341-E, how big is your manual? Maybe there is a difference I dont know.
    Jan 2008
    queensland
    You dont have a standard converter do ya? I had a 2800stall in it for when I was gunna upgrade the cams, except that never happened haha, its done less than 80.000ks if you know anyone interested.
    Quote Originally Posted by mick08 View Post
    I can email it to you and you can have a look A340 is much the same as A341
    Jealousy is a curse
    Jan 2008
    queensland
    Hey Madmont, I might get that manual emailed zfterall, im seein some slight differences and wonder if the specs like piston travel etc are exactly the same, thanks again Madmont...
    I will need your email PM me
    Jealousy is a curse
  1. Line pressure cable oring on soarer auto trans.
    By mick08 in forum Tech and Conversions
    Last Post: 21-06-2013, 11:03 AM
  2. W55 auto trans to w50 manual trans conversion
    By remo80s in forum Tech and Conversions
    Last Post: 11-09-2011, 08:57 AM
