Results 1 to 9 of 9
Thread: 1976 Hilux 12R to 18R conversion
    Sep 2013
    Australian Capital Territory
    Default 1976 Hilux 12R to 18R conversion
    Hey all,
    I've got a 1976, single cab, RWD Hilux that i'm getting around in at the moment. I'm finding the 12R a little soft so I've been looking into doing a 18R conversion. I've heard that the 12R and 18R will both link up to the same gearbox as I want to keep the 4 speed column shift (It's just a cool touch). I've also heard that fabricating new engine mounts shouldn't be a huge job.
    I'm also looking into replacing the drum brakes on the front with some disk brakes.
    Does anyone have any experience with either of these conversions? Will it be as easy as i'm expecting or are there some things i'm missing? Any thoughts, suggestions or advise would be greatly appreciated.
    Basher Grease Monkey
    Feb 2007
    Default Re: 1976 Hilux 12R to 18R conversion
    12r engines are a little different to a 18r as they have half the bellhousing as part of the block.but if you have a w40 style box you can just change the bellhousing to suit.heres what you need for a 18r hilux on ebay now.http://www.ebay.com.au/itm/TOYOTA-19...item2eca20b29f.
    put up a pic of your gearbox for reference.
    Scott
    coronacoronacoronacorona
    Sep 2013
    Hey Scott,
    That's a bit of a bummer, I was under the impression that it would be a straight swap over. Do you think the gearbox for the 18R would link up to the current column shift setup from the 12R if I bought the gearbox that you linked me to?
    I can't really put up a good picture because the gearbox and engine is still all in the ute. Thanks for your advice tho.
    Feb 2007
    Sorry mate I can't be sure if your g/box will be the same for the column,as I mainly know 12r in coronas.check your vin plate to see if it has and trans id,if it is w40 you are in luck and only need to change bellhousing.
    Sep 2013
    Thanks for the help.
    Nov 2010
    ACT and NSW
    From what I've read the 40 series Hiace and Hilux from early 80's have a disc setup that utilises the same ball joints. Ive been looking into similar stuff for my RH11 Hiace ute (got a couple of Hilux's like yours floating around too but they're pretty far gone.). I've also got a 93 Hiace parts van that was hoping to use a few bits from but I haven't had a chance to have a good look at the frond end setup compared to the RH11.
    Be sure to post up if you find out anything else usefull about this swap.
    Junior Member Backyard Mechanic scottreichstein's Avatar
    Aug 2011
    ive done the brake conversion on my lux
    try find a sr5 or duel cab they had discs on the front
    I just sold my spare set I had I paid about $600 for my parts to do the conversion
    as said above the 12r does have the bell housing as part of the block but if its a w series box in it the gearbox crossmember should be the same just bolt up the motor to a box and weld in the engine mounts
    should be a pretty straight forward conversion
    ive got a 12r box I recently pulled out and replaced can get a pic for u tomorrow to compare to the 18r one
    RIP st141 died doing what it loved http://www.facebook.com/media/set/?s...type=3&theater
    1ggte hilux massive 143rwkw http://www.toymods.org.au/forums/sho...724&highlight=
    corolla sportivo daily LIFT
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    if you want an 18rg i know of a guy local to canberra whos has a couple he is happy to see find a new home, send me a pm if you are interested at all
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
    Junior Member Grease Monkey Pagie84a's Avatar
    Feb 2012
    Sa
    Quote Originally Posted by bmxer54 View Post
    Do this skip the single cam theyre shite
  1. 1976 Hilux 12R to 18R conversion
    By Matt.L in forum Engine & Driveline Conversions
    Last Post: 13-03-2014, 10:10 PM
  2. Hilux conversion
    By Ve_ssv in forum Tech and Conversions
    Last Post: 29-08-2013, 06:56 AM
  3. Replies: 1
    Last Post: 06-08-2011, 12:44 PM
  4. 1976 TA23. 2t conversion to Sr20
    By Roachy93 in forum Tech and Conversions
    Last Post: 22-03-2011, 07:04 AM
