Results 1 to 7 of 7
Thread: 1jz single turbo questions..
    May 2012
    Default 1jz single turbo questions..
    hi there. just putting a 35r on my 1jz. non vvti just wondering where do i connect my water lines to. can someone just upload an image and circle it for me as i cant seem to work out whats what. thanks.
    May 2012
    Default Re: 1jz single turbo questions..
    also just wondering what do i do with all the extra lines left over from the stock twins. ive tried googling but without images its hard understand what some people are on about
    Junior Member Grease Monkey BEVANI's Avatar
    Apr 2008
    you can connect one water line to the top water inlet and block the 2nd on off. i joined the other end of the water to the line that connects near the thermostat, block off the back one near the fire wall.. same with the oil feeds in the side of the block you will need to block one of them also
    If in doubt, drift her out! Steer from the rear! less traction,more action! simple!
    BURN RUBBER
    ░░▒▒▒▓████ JZA61 FTW!
    May 2012
    nevermind!!!
    May 2012
    Quote Originally Posted by BEVANI View Post
    i bought this line kit off ebay.
    Turbo OIL Water Line Toyota 1JZ GTE 2JZ GTE W Garrett GT30R GT3582R GTX3582 | eBay
    which lines do i use for the coolant? do i have to modify the inlet nipple to suit the lines?
    I'm doing the same conversion at the moment. Here's what I've done.
    On the top radiator outlet from the head I removed both of the copper fittings. I had a speedflow threaded bung welded over one and blocked the other one with a bolt and some sealant.
    On the metal water line that runs around the head, I had one of the outlets crimped and brazed closed.
    So your lines should run: From the top radiator outlet to the turbo, out the other side of the turbo to the copper fitting at the back of the water pump.
    I bought a fitting kit similar to yours, I didnt end up using most of it as I went with speedflow fittings instead.
    Heres some photos of my setup thusfar
    ImageShack® - Online Photo and Video Hosting
    Cheers.
    Matt.
    Gen 3 Liberty RX Wagon.
    MX83 Cressida - 1JZ Powered.
    Gen 1 Liberty Sedan - EJ20T Powered.
    May 2012
    Quote Originally Posted by mutnose View Post
    Cheers.
    thanks mate pics are very useful.
  1. a few 1jz single turbo conv questions
    By AMZ020 in forum Tech and Conversions
    Last Post: 27-04-2010, 11:01 AM
  2. 1jz single turbo VVTI block differences to 1jz twin turbo
    Last Post: 06-02-2008, 12:57 AM
